VWVortex.com - Door panel removal?
    Results 1 to 9 of 9
    Thread: Door panel removal?
    1. Junior Member
      Jun 27th, 2011
      Detroit
      2011 JSW, 1991 Porsche 928GT
      07-09-2012 12:17 AM #1
      Hey guys,
      Searched for write up but didn't see anything. I'm going to add front and rear puddle lights a la ToeBall.
      First step is to remove the door panels (aka door trim) and I was hoping there was a write up or guide you could point me to so I don't break anything unnecessarily.
      Feb 18th, 2002
      OH
      2017 GTI
      07-09-2012 01:56 PM #2
      It's essentially the same procedure as the DIY's for the MKV door panel removal. I busted the trim piece for the window switches, so don't pry on it too hard.
      Quote Originally Posted by AO928 View Post
      Hey guys,
      May 30th, 2010
      Houston, TX
      10 JSW TDI, 12 R
      07-09-2012 07:24 PM #3
      I just remove the screws along the bottom, and then pull it straight out from bottom up. If you break any of the clips, VW will try to make you buy a whole door card. You can get just the clips from Bold-Sport though.
    4. Junior Member
      Jun 27th, 2011
      Detroit
      07-09-2012 09:41 PM #4
      Quote Originally Posted by aenea View Post
      Quote Originally Posted by ToeBall View Post
      Thanks guys. I already got some spare clips from bold-sport when I ordered the puddle lights.
    5. Member dubidoobs's Avatar
      Jan 7th, 2003
      On Top of West Durty Jurzy
      MKII Alpine White GTi 2.1 16V (in the works) | "MKVI" PGM 2.0L CR TDi Wagon
      07-10-2012 10:22 AM #5
      way to plan ahead!
      how about a write-up once you get cracking?
      a bad day in a Volkswagen, is better than a good day in a Honda...
      MKII Alpine White GTi 2.0/1 16V (in the works)
      MKVI PGM 2.0L 6MT TDi Wagon (daily driver)
      SLAM-N-EURO'Z
    6. Junior Member
      Jun 27th, 2011
      Detroit
      07-10-2012 10:54 AM #6
      It'll be a while before I get to it. Heading out of town on Thursday for a Porsche 928 event in Wichita. Probably wont get to touch the JSW until later this month, but my plan is to do a comprehensive writeup at least on the door panel removal as the puddle light have already been done.
      Apr 19th, 2007
      CT
      07-11-2012 02:40 PM #7
      Most JSW questions are answered in the MKV Golf/Jetta DIY forums.
      MKV Door Panel Removal
    8. Junior Member
      Jun 27th, 2011
      Detroit
      07-20-2012 01:45 PM #8
      Quote Originally Posted by brian81 View Post
      Just wanted to say thanks for the linky. Worked great! Did the driver side door marker last night. Now that the learning curve is mostly over, the next three should go speedy quick.
      Apr 19th, 2007
      CT
      07-22-2012 12:17 PM #9
      Glad to help; there are a lot of hidden resources on the forum.
      A lot of things that are daunting to first-timers don't always require buying a Bentley manual to become fairly simple.
