Page 1 of 2 1 2 LastLast
Results 1 to 35 of 49
Thread: Supercharged Rwd 2.8 build/timeline
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    07-09-2012 07:37 AM #1
    So I'm finally going to post a build thread of sorts. I have had my b5 for 4 years. I got it before my twin daughters where born cause it was a safe awd car. I wanted out of the vw Scence so I bought and a4.100% stock I bought it for 4200$ with 86k.
    Found a guy with a built block (was a machine shop in blairstown nj an s4 guy had a 2.8 block with 2.8 heads, crank and pistons where done didnt need heads they where stock) soon after I bought car. So I peeled $$ I bought the block and started buying the supporting stuff coil overs bought every bold on you can get for a 2.8. ( pulleys cold air, exhuast, nuespeed chip)
    I got a little derailed cause the car got hit by a hit and run driver. As I pulled in my ally behind my house. Damage wasn't bad but it still was enough.
    So I drove hoopty for a little.
    Than I got some black panels and here is 2010 at cult classic
    No clue what I was thinking, I look at it now and it was cool but not at all
    And I kept it moving tons of wheels lip kits body kit was a cheap fix for getting blasted by hit and run.
    First wheels I bought for the car where 18x9.5 tsw vx-1s
    I was content car was running well wheels where big chrome and ugly.
    This is 2010 as well on b6 wheels
    So now we get to the good stuff.
    So I wanted more power and I had a good place to start. Car handled like it was on rails. Was reasonable quick for a 2.8.
    But I wanted more power and had been reading about g2 supercharger from pes tuning.
    I bought that ****er brand new for $3727.36
    And I installed took 6 hours
    So I drove car for a few months and started to here clicking from the trans.
    Than on march 16th 2012 I separated 2 gear from the final drive in glorious fashion. Sounded like an anti tank cannon went off.
    Felt like all 4 wheels left the ground.
    So I towed it home.
    This is how it sat for 3 month.
    During the 3 months I decided to do a Rwd conversion. So I bought a trans with 80k for 200$.
    And I pulled the Torsen off for welding.
    Yesterday 7/8/12 I started work. Spent day pulling cat back. Driveshaft, axles and getting ready to pull trans.
    Car already has a lw flywheel so I'm doing a unsprung 6 puck ceramic clutch and new release bearing while I'm in there and doing the control arm kit while it's down as well.
    Will update often with progress and other info. Some picture whoring
    Somewhere around 2011 I started racing my a4 and my mk3 aba so there are videos too.
    Old and new pictures
    Video
    http://[IMG]http://i1189.photobucket....mp4[/IMG]
    Untitled from james apgar on Vimeo.
    J&J autosport
    Catch me if you can
    Supercharged Rwd b5--http://forums.vwvortex.com/showthrea...build-timeline
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    07-09-2012 07:39 AM #2
    J&J autosport
    Catch me if you can
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    07-09-2012 12:29 PM #3
    tomorrow is my day off so i hope to have the trans out of the car that i destroyed. and it will give me a chance to inspect flywheel and pp.
    was going to bend up a wrench to get around the subframe to remove bolts on bottom of trans case but i might just lower the subframe a little bit and make life easy. ill still need to bend the wrench though
    picking up some nuespeed swaybars and stock rear bumper and a hood this week all my ly7a paint code.
    J&J autosport
    Catch me if you can
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    07-09-2012 09:55 PM #4
    Just got home from work was looking through my photo bucket and found pictures of the diff disassemble.
    J&J autosport
    Catch me if you can
  5. Junior Member Lord-O's Avatar
    Jul 14th, 2009
    the sticks of MI
    2002 Jetta 1.8, 1998 A4 S/C
    07-10-2012 04:13 PM #5
    Good to see someone else with a 2.8 and a g2.
  6. Member aledelic42's Avatar
    Jul 28th, 2008
    Bethlehem, PA
    99.0 A4 Avant
    07-10-2012 05:47 PM #6
    I still wanna test fit those front lips some time!
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    07-11-2012 06:24 AM #7
    Quote Originally Posted by aledelic42 View Post
    Reiger got mangled from retread off a tractor trailor. Along with bumper and passanger for light.
    I have eBay Reiger rep still. Car is to low for lip right now.
    If your home for summer still I'll gladly swing up to Bethlehem.
    J&J autosport
    Catch me if you can
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    07-11-2012 06:26 AM #8
    Quote Originally Posted by Lord-O View Post
    hi friend. There few and far between glad someone else is rolling one
    J&J autosport
    Catch me if you can
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    07-11-2012 06:33 AM #9
    Got the bad trans out of car yesterday. When I spin the driveshaft flange is sounds like a pepper mill pulled diff plug and a ton of metal was on the magnet. I know some is expected but this looked like science experiment. I'll break trans down on a rainy day, when It went I swear it felt like I removed 2nd gear from the final drive. Now with out opening trans just hearing it I know I sheared something off final drive 4000rpm launches
    J&J autosport
    Catch me if you can
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    07-12-2012 06:54 AM #10
    So car is back together it's Rwd. The swap was easy and straight forward. During installation I knocked one of the heater core pipes loose started getting soaked in colorant. Couldn't tell what it was or where it was coming from. Had to pull the blower to locate the leak. Stupid cross over metal coolant tube.
    Other than that it's cool. NEED MORE TIRE. 205/40/17s have no grip at all. Put my foot down in first gear and she spins like a beast. Depending how I get on the power in second same thing. And that's driving straight.
    It's also time to replace the diff carrier bushings. But hey for 300$ I might just but the o34 aluminum cross member bushing set up
    J&J autosport
    Catch me if you can
  11. Member It's Big Ty's Avatar
    Feb 19th, 2011
    MD
    LG9R GTI VR6, '57 Ford Thunderbird
    07-12-2012 06:35 PM #11
    Is something wrong with your passenger side rear fender flare? In the pics it looks awkward and out of shape. Do you plan on getting a new rear bumper?
    Tyler
    Instagram: @itsbigty
    SteeLow
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    07-13-2012 06:20 AM #12
    Quote Originally Posted by ChampagneA4 View Post
    Actually I'm supposes to pick up new hood and rear bumper tonight off a kid on Craigslist.
    End of last summer that happened.
    Onto the rear fender flare.those big old tsw 18s. When I bought those wheels I met a kid In a parking lot paid 150$ and my stock wheels. Guy left before I had car on the ground. When I put car on ground I was on the rear fender. I was stuck in hamburg Pa about an hour from where I live with my car on its ass.
    So I used the jack handle to roll fender. And drove home scuffing tire even on straight always. Not the nicest job and it's not really out of shape. Haven't had time to go at it with hammer and dolly. But I will add it to list of things to do
    J&J autosport
    Catch me if you can
  13. n00b
    Oct 18th, 2007
    france
    07-14-2012 04:38 PM #13
    Good joob What gearbox you use ?
  14. Member
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    07-15-2012 06:28 AM #14
    Quote Originally Posted by Archy View Post
    Gear box is a standard o1a 5 speed.
    J&J autosport
    Catch me if you can
  15. Member
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    07-15-2012 06:35 AM #15
    I'm at 107 miles on Rwd swap feels good. I'm getting adjusted to the hp coming on totally different.
    Car deff feels quicker in Rwd form ( less drivetrains loss) boost feels like it kicks harder.
    Surprising people in when I stomp on it in 2nd and the car cocks sideways
    Today I'm going to add a little height to the front and rear. Might swap out rear springs for something stiffer. But today is r&d for suspension tuning for Rwd set up.
    Also ordering new diff bushings from o34.
    J&J autosport
    Catch me if you can
  16. Member
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    07-19-2012 06:25 AM #16
    What's left of the front Outter cv joint. This is what keeps load on front wheel bearing so it doesn't literally fall the **** out when your driving
    J&J autosport
    Catch me if you can
  17. Member
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    07-19-2012 07:27 AM #17
    New rear bumper and hood is on car. Been a long time since I saw the body in OEm form. It's nice.
    And I got a hammer and dolly set from body shop at work. "hey I sell cars, but can I borrow a hammer and dolly set?" body shop manager says He can fix what ever I'm about to **** up with hammer and dolly.
    I smile
    Always fun to learn.
    Any way traded my 17x7.5 Asa's for 18x8 msw wheels 20mm spacers and lugs. ****ing monster truck tires on them 235/40/18 I'm picking up some 215's today or tomorrow for the front
    J&J autosport
    Catch me if you can
  18. Member MikkiJayne's Avatar
    Jan 1st, 2007
    UK
    07-19-2012 02:53 PM #18
    Quote Originally Posted by b5blazing View Post
    Why leave the guts in it?
  19. Member
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    07-19-2012 03:15 PM #19
    Quote Originally Posted by MikkiJayne View Post
    i didnt drive it like this
    There actually pressed out now. i was just giving example of whats left. i didnt take any pics after i pressed them out though You can leave them in and weld them.
    But It would be worse thing ever to have 6 ball bearings bouncing around at speed. that would be new deff of granade
    J&J autosport
    Catch me if you can
  20. Member MikkiJayne's Avatar
    Jan 1st, 2007
    UK
    07-19-2012 05:45 PM #20
    Exactly what I was thinking I'd just take everything out rather than welding the bits in - reduce unsprung weight by a few ounces
  21. Member
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    07-24-2012 07:22 AM #21
    Finally had a few minutes to check stuff out on the car change some things.
    Got the 215s on up front 235s in the rear. The rear is nice and sticky but still break loose under wot. 1st and 2nd. Not as bad as the 205/40/17s. That was like driving in the snow.
    SLIDEWAYZ It's so much ****ing fun. And It's nice to drive fast again and not rub.
    Switched plugs to the colder heat range, car loves it! Thought it was just heat soak I was experiencing,
    But I switched plugs and car peaks at 8psi boost feels smoother.
    I did order Stern density line diff carrier bushings yesterday from ApTuning. Went with stern instead of 034s product due to the fact I run a stern snub mount and trans mounts.
    Get rid of the clunk I keep getting on smokey launches.
    Still gotta do control arm kit had set out to do that on Sunday and wound up changing suspension and doing plugs.
    J&J autosport
    Catch me if you can
  22. Member
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    08-09-2012 06:42 AM #22
    Trying to get stuff done before vag fair.
    J&J autosport
    Catch me if you can
  23. Junior Member jhad03's Avatar
    Sep 28th, 2012
    nazareth, pa
    jetta3 aba
    09-29-2012 10:20 AM #23
    updates!
    J&J Autosport
    phillyscca.com
  24. Member
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    10-01-2012 07:23 AM #25
    Updates
    Car is still running well.
    CCT went bad last week that's got me held up waiting on parts and tool.
    Others than that
    Did stern poly carrier bushings, and a stern power ring. It still clinks and for 100$ it was worth a shot compared to the 250$ for apikol mount. But I still need it.
    From dubs on the Delaware
    J&J autosport
    Catch me if you can
  25. Member
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    10-03-2012 07:42 AM #26
    Waiting for tools suck. Stupid 3660 cam tensioner tool. Been looking at new wheels. I bought some Mkv steelies 15x7 to mount race rubber on . Hoping to get car done for 10/14 race in warminster pa. I'm curious to see car on 15s with 205/50/15s. The steelies with tires mounted are 2in smaller than my 17s currently and 1 1/2 smaller than OEm 16s.
    Would like to test fit them this weekend. I fitted wheels before I mounted tires to make sure they clear brakes and I'm good offset is okay
    But I have been looking at super leggera's. 17x8 maybe 17x10 in the rear. With I could find an old set of ur Quattro Ronals.
    J&J autosport
    Catch me if you can
  26. Member
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    10-09-2012 07:36 AM #27
    There tar and chipping all the roads around me videos u soon
    J&J autosport
    Catch me if you can
  27. Member
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    10-20-2012 07:44 AM #28
    J&J autosport
    Catch me if you can
  28. Semi-n00b
    Jun 17th, 2012
    Lockport, NY US
    2-1998 audi a4
    10-20-2012 10:43 AM #29
    Almost lost that lol
  29. Member
    Feb 3rd, 2011
    Lombard, IL
    99.5 A4 1.8TQM
    10-20-2012 04:04 PM #30
    Damn I am super glad that your car is all stock body panels again. That kit was atrocious! I dig all the work you have done to the car.
    Alex
    Strictly Pleasure/Zero Clearance/Stretch Your Legs IX
  30. Member
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    10-22-2012 07:25 AM #31
    Thanks man. Been through hell and back with this thing.
    I'm fighting with my rear diff right now, I'm not sure how long it's going to hold up.
    330hp and stock rear diff, not a match made if heaven. So I'm looking at rear diff options.
    J&J autosport
    Catch me if you can
  31. Member ray4624's Avatar
    Jul 23rd, 2010
    UMass
    98 a4 1.8tqm
    10-22-2012 01:36 PM #32
    o1e swap maybe?
    car looks a million times better now then it did before. bet its super fun with the rwd and supercharger.
  32. Member
    Apr 30th, 2011
    williams twsp pa
    A unicorn
    10-22-2012 03:02 PM #33
    01e trans is just the 6 speed. All b5s that are quattro run the same rear diff. kinda sucks, i was thinking of using an s4 rear diff till i found out they where the same.
    The early 86-89 porsche 944 diffs supossedly fit in b5 diff case with some dremmel work. So im looking into finding a second and third diff to mess with.
    i might just hit the u pull it yard this weekend and grab one to take apart and see whats what.
    J&J autosport
    Catch me if you can
  33. Member It's Big Ty's Avatar
    Feb 19th, 2011
    MD
    10-22-2012 03:29 PM #34
    The S4 and Tiptronic A4 rear diffs are different than the manual A4 rear diff. Not sure if they are stronger but the final drive ratio is 4.11.
    Tyler
    SteeLow
  34. Member ray4624's Avatar
    Jul 23rd, 2010
    UMass
    98 a4 1.8tqm
    10-22-2012 07:14 PM #35
    i knew the tip was the same as the s4 and required for the swap but for some reason i just assumed it was stronger. never heard of the 944 dif though. interesting
