Results 1 to 1 of 1
Thread: 1990 Audi 90 parting out
  1. Junior Member
    Apr 9th, 2011
    Harrisburg, Pa
    90 audi 90 (PROJECT 2.7T), 93 audi 90(5spd conversion), 91 passat vr6(PARTING OUT),92 passat 16v
    07-09-2012 08:18 AM #1
    I have a whole car that i am parting out everything except the shell and wheels. Call for parts and prices can send pics via txt message. All pricing is plus shipping unless otherwise noted. All body panels can be painted to match your color. Send me your paint code. All prices are o.b.o with in reason. If you need something thats not listed ask I may have it laying around.
    Thank you
    Jason
    Jk Performance
    717-903-8784
    -5 cyl 10 valve engine needs timing belt and water pump $350 if i do the water pump n belt its $450 If you want the fuel injection unit add $50 to the price of the engine
    -5spd trans work great no problems shifts smooth $275
    -Hood primered ready for paint $75 or $120 paint to match your color
    -fenders $25 each or $50 each painted
    -Grille $35
    -Headlights $25 each
    -Corner lights (yellow) $10 each
    -Radiator $225 cleaned no leaks
    -A/C compressor works great $100
    -Fuel injection unit w/ pressure regulator $85 add $15 for injector lines
    -Air box $25 $30 w/intake hose
    -Abs unit $150
    -Brake calipers (Front) $30 each w/ mounts painted red
    -Brake calipers (Rear) $25 each w/ mounts painted red
    -Used cv shafts $35 each
