Results 1 to 14 of 14
Thread: Rattle after VR Strut Mount Upgrade.
  1. Member ejg3855's Avatar
    Sep 23rd, 2004
    Rochester, NY
    1989 16v, F250 Diesel, 2001 TT
    07-09-2012 02:23 PM #1
    So I did the VR strut mount upgrade from GAP.
    http://www.germanautoparts.com/Volks...spension/198/2
    I realized that after I did everything that the suspension unloads and the top hats rattle. It only happens when I go over holes in the road, it seems like for that instant of a second the rubber bushing drops and the suspension is then cought by the hat.
    Any ideas why this might be happening, should I have a front sway bar to help balance the drop on the front a-arms?
    HAD - 1991 V8Q | 1990 Jetta 1.6 | 1984 Rabbit 16v | 1990 Audi CQ | 1988 Audi 80 10v | 2005 GTi 1.8T | 1991 GTI 2.0 ABA | 2002 Audi TT S362 |
    HAVE - 2001 TT 180Q F23 wifes | 1989 Jetta VR6 GLI | 2004 F250 PowerStroke |
    Looking for Custom Tuning, Shoot me a PM ! ME7.X !
  2. Member ejg3855's Avatar
    Sep 23rd, 2004
    Rochester, NY
    07-09-2012 11:08 PM #2
    So just put in a really stiff front sway bar?
  3. Member under the radar's Avatar
    Mar 5th, 2007
    NOR-CAL COASTSIDE
    disco, new wave, rave era german iron...and a Japanese V8 with a tailgate
    07-09-2012 11:31 PM #3
    shouldn't rattle or clunk at all. something didn't get put together correctly.
    Quote Originally Posted by spoon! View Post
    I'll go if Paul goes.
    Rod Blagojevich - Team My Little Pony
  4. Member PDXGTI8V 2.0's Avatar
    Oct 11th, 2005
    Portland ORYGUN
    + over 7500 posts pre-ban
    07-09-2012 11:47 PM #4
    and heres how it goes together...go back and put it together properly
    My 91 GTI 8V, original owner stylz, yo!: http://www.flickr.com/photos/4144775...13544433/show/
  5. Member PDXGTI8V 2.0's Avatar
    Oct 11th, 2005
    Portland ORYGUN
    07-09-2012 11:50 PM #5
    are you using Bilstein, Koni, or Corrado G60 struts like the kit says you need to use? If youre not using those struts, then theyre not gonna fit correctly without the special adapter that Rapid Parts use to sell with their VR6 strut conversion....but I'd first make sure you put things together properly
  6. Member ejg3855's Avatar
    Sep 23rd, 2004
    Rochester, NY
    07-10-2012 06:05 AM #6
    Thanks for the help, all is assembled properly.
    I am using KYB's in the front, the part number for corrado/mk2 struts is the same?
    http://showmetheparts.com/kyb/
    Part Number 235614 for Corrado and Jetta Mk2
    I am not sure if this is the issue but I have a hunch it could be the right path.....
  7. Member ejg3855's Avatar
    Sep 23rd, 2004
    Rochester, NY
    07-11-2012 06:31 AM #7
    this rattle sucks.
  8. Member PDXGTI8V 2.0's Avatar
    Oct 11th, 2005
    Portland ORYGUN
    07-11-2012 12:47 PM #8
    have you completely taken it apart yet? it should be fairly obvious once you get it apart....do you have all the items listed in the above parts diagram?
  9. Member rysskii3's Avatar
    Apr 18th, 2006
    SoCal
    MKII Race Car
    07-11-2012 12:52 PM #9
    I'm using the same kit minus the lower metal cup thing with h&r coilovers, no rattling or anything.
    OIF 06-07: Hospital Corpsman FMF. Al Habbaniyah, Al-Anbar Province, Iraq.
    Mk2 16v parts for sale.
    Mk2 Golf_GL 16v @ Streets of Willow Raceway.
    Project Гольф Мк2 (Carbed)
  10. Member ejg3855's Avatar
    Sep 23rd, 2004
    Rochester, NY
    07-11-2012 12:54 PM #10
    Quote Originally Posted by PDXGTI8V 2.0 View Post
    I have taken it apart about 10 times, its per the diagram.
    The only thing I really notice is when I jack up the car the suspension droops (normal), I think this is my noise tho when I hit negative bumps ( unload instead of compress ) the suspension drops and rattles.
    I will be evaluating again after work tonight.
  11. Member PDXGTI8V 2.0's Avatar
    Oct 11th, 2005
    Portland ORYGUN
    07-11-2012 12:54 PM #11
    Quote Originally Posted by rysskii3 View Post
    you mean the spring seat? yeah, you wouldnt use the spring seat with your nice coilovers...
  12. Member rysskii3's Avatar
    Apr 18th, 2006
    SoCal
    MKII Race Car
    07-11-2012 12:57 PM #12
    In the picture of the whole kit on German auto parts, its the middle large metal part. My coils didn't come with it, bought them used, so I just installed them just like how they came out of another mk2.
  13. Member
    Aug 22nd, 2004
    clifton, Nj 07011
    07-11-2012 01:47 PM #13
    Do the top hats turn while you turn the wheels? If not; the spring may be binding when turning and then unleashing when you hit some bumps. Even still, after a while that bushing should get stuck in there good enough to not bounce around anymore.
    You could also wrap some hose under the top hat
  14. Member ejg3855's Avatar
    Sep 23rd, 2004
    Rochester, NY
    07-11-2012 02:13 PM #14
    Thats exactly what appears to be happening the rubber bushing isn't staying in its housing when the suspension becomes unloaded, I have zero issues when driving with with compressible bumps.
