Results 1 to 4 of 4
Thread: Fuel Distributor Lines (with pics!)
    Apr 7th, 2007
    SD, CA
    1992 GLI - motronic.
    07-09-2012 04:20 PM #1
    Just picked up my GLI and have started right away to make it happy again. I'm currently tracking down the culprits to a rough idle and hard start, and couldn't help but notice that there's some tears/gashes in my fuel distributor lines. I'm figuring I may as well replace these while I do the injector seals and maybe the CSV (hard start when cold). Vacuum testing to follow...
    Is it just regular old fuel hose like this http://www.ecstuning.com/Volkswagen-...ines/ES466811/ ? Or do I need to replace the hard and soft lines as one piece? If so, where can I find/buy them? (other than vw or a junkyard)
    PICS FOR CLICKS!
    These are the lines I am referring to:
    most noticeable crack:
    Feb 28th, 2011
    South Holland, IL
    92 GtiT
    07-09-2012 04:27 PM #2
    that rubber is just a coating.. the older vws didnt have it and the lines rusted due to age... you shouldnt have any problems with the way those lines look.. one thing you might check into is the rubber o-ring around the injectors, they sometime cause rough idle. one other thing that came up in technical bullitens is a filter in the main line banjo bolt going to the fuel distributor. it gets clogged and starves fuel.
    Apr 7th, 2007
    SD, CA
    07-09-2012 05:19 PM #3
    Thanks for the info. I'm new to the 16v so I'm still learning. " main line banjo bolt going to the fuel distributor"
    ^location? Bentley isn't quite that informative...
  4. Member
    Feb 28th, 2011
    South Holland, IL
    92 GtiT
    07-09-2012 09:42 PM #4
    big gold line on the distributor in the first picture to the right. should have an arrow pointing inward on the base..
