its leaking past your rings and being burned off... it doesnt just disappear. try a thicker oil and get a compression test done.
#1
alright here is the issue im going through a qourt of oil every 2,000miles it started doing this about a month ago after i changed my spark plugs. every place i park there is no oil puddles and i have no oil burning like no smoke from the tail pipe and the spark plugs have no black on them . i looked for a leak cant find one. do you think it can be leaking oil only when im driving? and does anyone have an idea on where my oil is going?
i have a 2000 golf with the 2.ol manul trans
#2
2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
#3
im using 5w 30 max life right now should i move to 5w 40? it doesn't seem to burn oil. well it doesn't smell like it and its not smoking.I HOPE its not burning oil
#4
these motors are famous for burning oil, and you may not actually see it.
FS:Sunroof Deflector
