Results 1 to 12 of 12
Thread: 01M Solenoid Problems, 99.5 Jetta Multiple Codes in VCDS
  1. Member ddd8896's Avatar
    Jan 9th, 2012
    2005 Golf TDI, 1984 Rabbit Diesel, 1997 Cabrio, 2011 Golf TDI
    07-09-2012 07:47 PM #1
    Hi, I bought a 1999.5 Jetta with 217k as a project car and bought it with solenoid codes. The car could be manually shifted into 1st and 2nd but if shifted into "3" it would stay in 2nd. If I put the car in "D" it stays in 2nd with no shifting. I ran a vcds scan and heres what came up.
    Saturday,07,July,2012,20:01:08:35496
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 9M - VW Jetta IV
    Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
    75 76
    Mileage: 349970km/217461miles
    Address 01: Engine Labels: 06A-906-018-AEG.lbl
    Part No: 06A 906 018 JC
    Component: MOTRONIC M5.9.2 AT V01
    Coding: 00001
    Shop #: WSC 09218
    VCID: 6CDDF88C1C90D69
    2 Faults Found:
    01165 - Throttle Body Control Module (J338)
    55-10 - Adaptation Not Successful - Intermittent
    17952 - Angle Sensor 1 for Throttle Actuator (G187)
    P1544 - 35-10 - Signal too Large - Intermittent
    Readiness: 0010 0101
    Address 02: Auto Trans Labels: 01M-927-733.lbl
    Part No: 01M 927 733 EN
    Component: AG4 Getriebe 01M 4386
    Coding: 00000
    Shop #: WSC 00000
    VCID: 80053C3C8018A29
    6 Faults Found:
    00258 - Solenoid Valve 1 (N88)
    36-00 - Open Circuit
    00260 - Solenoid Valve 2 (N89)
    00262 - Solenoid Valve 3 (N90)
    00264 - Solenoid Valve 4 (N91)
    00266 - Solenoid Valve 5 (N92)
    00270 - Solenoid Valve 7 (N94)
    Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
    Part No: 1J0 907 379 G
    Component: ABS 20 IE CAN 0001
    Coding: 03504
    Shop #: WSC 00066
    VCID: 356B1DE80F5A571
    1 Fault Found:
    01276 - ABS Hydraulic Pump (V64)
    16-00 - Signal Outside Specifications
    Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
    Part No: 1J0 909 609
    Component: C AIRBAG VW3 SG 0002
    Coding: 00067
    Shop #: WSC 00066
    VCID: ECDD788C9C90569
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 17: Instruments Labels: 1J0-919-xxx-17.lbl
    Part No: 1J0 919 951 C
    Component: A4-KOMBIINSTR. VDO V57
    Coding: 06242
    Shop #: WSC 00000
    VCID: 30652CFCF038729
    1 Fault Found:
    01039 - Coolant Temperature Sensor (G2)
    30-10 - Open or Short to Plus - Intermittent
    Address 46: Central Conv. Labels: 1J0-959-799.lbl
    Part No: 1J0 959 799 AJ
    Component: 61 Zentral-SG Komf. 0001
    Coding: 04096
    Shop #: WSC 00066
    VCID: 86092A24A23C8C9
    Subsystem 1 - Part No: 1J1959801C
    Component: 61 Tõrsteuerger. FS0002r
    Subsystem 2 - Part No: 1J1959802D
    Component: 61 Tõrsteuerger. BF0002r
    Subsystem 3 - Part No: 1J4959811C
    Component: 61 Tõrsteuerger. HL0002r
    Subsystem 4 - Part No: 1J4959812C
    Component: 61 Tõrsteuerger. HR0002r
    10 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    53-10 - Supply Voltage Too Low - Intermittent
    01038 - Central Locking Thermal Protection
    35-10 - - - Intermittent
    01331 - Door Control Module; Driver Side (J386)
    00943 - Heated Exterior Mirror; Driver Side (Z4)
    35-00 - -
    01358 - Internal Central Locking Switch; Driver Side (E150)
    27-10 - Implausible Signal - Intermittent
    00912 - Window Regulator Switch; Front Left (E40)
    01332 - Door Control Module; Passenger Side (J387)
    00944 - Heated Exterior Mirror; Passenger Side (Z5)
    35-00 - -
    01333 - Door Control Module; Rear Left (J388)
    01334 - Door Control Module; Rear Right (J389)
    Address 56: Radio Labels: 1J0-035-18x-56.lbl
    Part No: 1J0 035 180 D
    Component: RADIO 3CP 0001
    Coding: 02403
    Shop #: WSC 00241
    VCID: 2045DCBCA0D8C29
    No fault code found.
    End ---------------------------------------------------------------------
    I cleared the solenoid codes and they would immediately come back. With that in mind I did alot of research and came to the conclusion that I should change the trans wiring harness. I purchased the ribbon style harness from electrical advantage in Oregon. I installed this trans harness today without breaking any solenoid clips etc. also changed the trans filter and fluid closely following bentley instructions. After changing all this I cleared the Trans Fault Codes, they went away and said "No Codes Have Been Found, System is not ready for interrigation". I started the car and went for a drive figuring that I should so the computer would do its thing and then I would run vcds later. The trans acted exactly as it did before with the same problems. I turned the car off and ran vcds again. Heres what came up.
    Tuesday,10,July,2012,18:35:45:35496
    75 76
    Coding: 00001
    Shop #: WSC 09218
    Readiness: 0110 0101
    Coding: 00000
    Shop #: WSC 00000
    8 Faults Found:
    00281 - Vehicle Speed Sensor (G68)
    03-00 - No Signal
    00652 - Gear Monitoring
    Coding: 03504
    Shop #: WSC 00066
    1 Fault Found:
    Coding: 00067
    Shop #: WSC 00066
    1 Fault Found:
    Coding: 06242
    Shop #: WSC 00000
    1 Fault Found:
    Coding: 04096
    Shop #: WSC 00066
    11 Faults Found:
    00953 - Interior Light Time limit
    25-10 - Unknown Switch Condition - Intermittent
    35-00 - -
    35-00 - -
    Coding: 02403
    Shop #: WSC 00241
    So now theres 2 NEW!! trans codes. . . Im making things worse apparently. How could these codes be new? Im stumped here and dont know where to go from here. Im thinking to check the resistance on the solenoids? Any advice is greatly appreciated. Thank You . Im calling for help from the 01M god
    03-00 - No Signal
  2. Member ddd8896's Avatar
    Jan 9th, 2012
    07-10-2012 02:44 PM #2
    Correct me if I'm wrong, I checked as many grounds as I could find. 3 ground mounts under the battery box, a ground strap going directly to the trans, and a ground under the plenum about a foot after the TCM. Drove the car and no difference, cleared all codes etc they still come back. dse anyone know a good DIY thread for ohm testing the TCM ? thanks
  3. Member ddd8896's Avatar
    Jan 9th, 2012
    07-10-2012 08:36 PM #3
    I pulled the TCM today to inspect it. I noticed these 2 rectangular electronic parts that seem to have seen excessive heat possibly, does anyone know if this could be the problem? Im no electrical engineer but that stood out to me because its flaking and discolored. How can I ohm test this unit ?!?!? I would like to swap a known working unit to see if this is the problem. Does anybody have one laying around? 01M 927 733 EN. Any advice is appreciated.
    [IMG]20120710_141847[/IMG]
    20120710_141436
    20120710_141541
  4. Member CoolAirVw's Avatar
    Mar 8th, 2007
    Kansas City Missouri
    85 Jetta TD sold 2001 Jetta Tdi, 2000 Jetta Tdi
    07-11-2012 02:46 PM #4
    You cant Ohm check a computer and see if its good. Diagnosis of a bad computer consists of checking everthing that could cause the problem (meaning everything that could cause your codes) and when you have eliminated everything else then you check powers and grounds to the computer with voltage drop tests.
    But if you have obvious burn damage then you might want to try a computer. Especially if you've had charging or battery problems and the car has been "jump started" or charged.
    Auto trans fluid change or flush will not make a trans fail. Stop spreading the wives tale/urban myth.
    ASE Master Certified Technician with L1 Advanced Diagnostic Rating Recently passed ASE certification for Light Diesel repair.
    www.KansasCityTdi.com
  5. Member ddd8896's Avatar
    Jan 9th, 2012
    07-11-2012 04:16 PM #5
    Im not sure what else could cause the codes. I highly doubt 6 of the 7 solenoids need to be replaced. And it was weird that when I put the new internal harness in that it threw 2 new codes. It makes me think that its electrical I just don't understand the correlation between the new and old codes. I also had a code that said throttle body adaptation unsuccessful intermittent. Another interesting thing that I noticed is that the ATF fluid temp reading in measuring block 005 would only jump between 0 and 11 deg celcius so when i changed the fluid I had to "manually" check the fluid temp. I know that temp sensor is brand new because its tied in with the internal harness.
  6. Member CoolAirVw's Avatar
    Mar 8th, 2007
    07-13-2012 01:55 PM #6
    Quote Originally Posted by ddd8896 View Post
    ya, I doubt it as well... but what if the ONE power wire that powers ALL the solenoids was broken and therefore none of the solenoids could "work" and the computer triggered codes for all of them?
    And what if that temp sensor got its power from the same place that all the solenoids got its power?
    Or maybe you just need a computer since the computer provides the power I mentioned. (assuming you have a 2.0 AEG)
  7. Member CoolAirVw's Avatar
    Mar 8th, 2007
    07-13-2012 02:02 PM #7
    check your solenoid power wire for 12 V. Of course you'll have to reinstall the computer for this check. If its got 12v then you may need to do this with it plugged in and working so you'll need to backprobe the connector. If there is reduced voltage or no voltage then verify the integrity of the wire between the computer and the solenoid connector and if that wire is good then you probably need that computer. I would lean torwards the computer since you have taken it apart and found damage.
  8. Member ddd8896's Avatar
    Jan 9th, 2012
    07-14-2012 08:16 PM #8
    To check the solenoid power wire for 12v stick the positive probe on female pin 1 of trans wiring harness and neg probe to any ground with ignition turned to on position?
  9. Member CoolAirVw's Avatar
    Mar 8th, 2007
    07-17-2012 01:33 PM #9
    any ground?? No. If a ground is your problem you'll chase your tail all day long.
    Always use the battery negitive as the ground and make sure there is no voltage drop between the battery post and the battery terminal clamp.
  10. Member ddd8896's Avatar
    Jan 9th, 2012
    07-25-2012 04:48 PM #10
    I just got a used "working" TCM in the mail, plugged it in and the same codes came up, cleared the codes and it said system not ready for interrogation. Start the car and drive, same symptoms same codes. Do I have to adapt the TCM to fix this? I don't think so because how would a different TCM remember the same codes? So i guess its the wiring. I pulled apart the looms. . . all of them. I checked that the TCM is getting power (Pin 23) and it reads the same voltage as battery. Checked all grounds again. checked the solenoid power wire for any king of voltage (Pin 67) and it reads .04-.06 V with the key turned but engine not started. I pulled the chip out of the old TCM housing and volt tested right to the actual pin 67 and get the same reading (all of this with neg probe on battery like you said). I didn't do that with the "new TCM" because the it has paint drops on the screws so the seller knows if its been opened. The car still throws solenoid codes 1,2,3,4,5,7 and G68 NO SIGNAL with either TCM in. How are these related? I feel like they are related by sharing a ground or power wire or something, i just don't know. Im losing hope unfortunately . Your help is greatly appreciated. Thanks
  11. Member CoolAirVw's Avatar
    Mar 8th, 2007
    07-28-2012 12:34 PM #11
    That is just a vag-com thing... vag-com rechecks for codes quickly, before the trans computer has finished the clearing process. This means nothing.
    No.
    Maybe...
    What about pin 45 coming from fuse 15? Why are you saying "same voltage as battery". You should be saying 12V. Is your overall battery voltage low?
    Oh, finally got around to doing what I suggested eh? This is your problem.... Now why would the TCM not be giving power to the solnnoies? probably because its lacking power going to it. Is fuse 15 blown or corroded? If fuse 31 providing pin 67 corroded? Checking voltage at the fuses can help identify voltage drops at the fuse. But I always pull out the fuses and scrape them clean anyway, because I've fixed many problems this way. Pin 63 might be a power to the TCm as well. Not sure by reading the schematic.
  12. Member ddd8896's Avatar
    Jan 9th, 2012
    07-28-2012 05:29 PM #12
    Battery is at 13.86v when the car is running and tcm main power wire (pin 23) is at 13.72v running. Is this the voltage drop you are referring to that could potentially be the problem? Solenoid power wire (pin 67) is at .15v when the car is running. Will check fuses tomorrow, I have to head out to work. Thanks.
