Results 1 to 5 of 5
Thread: Conical seat tuner lugs
  1. 07-10-2012 12:12 AM #1
    Anyone know where I can find some conical seat, ~47mm extended lugs WITH NARROW DIAMETER HEADS (tuner style I guess).
    Thanks!
  2. Member Kampy's Avatar
    Oct 1st, 2010
    SF Bay Area, CA
    Low and VERY slow chick car
    07-10-2012 01:39 AM #2
    Quote Originally Posted by JettaDude123 View Post
    Thanks!
    Yeah you have to do a stud conversion to m12x1.5
    But then again if you are into that kind of thing maybe you should just get a tuner
    8v Society #362
  3. 07-10-2012 04:04 PM #3
    Quote Originally Posted by Kampy View Post
    O yeah, I'm not talking about the diameter of the bolt itself, just the head..... Not sure if that's what you meant because stock is 14x1.5. I still need that bolt diameter and thread pitch, I just need a smaller head size to fit in the limited space on the surface of my wheel bolt hole, not the hole itself....if that makes any sense.
    For example: Right now I'm running the gorilla bolts, 14x1.5 (probably 28mm usable length) with what they call "small diameter bolts":
    http://www.gorilla-auto.com/small-di...g-nuts-page-03
    the shank is still the same diameter but the head is smaller. The problem is that they don't have anything longer than 31mm useable length.
    Anyway sorry if I'm confusing - so anyone have small lug headed extended bolts in the 47mm territory?
  4. 07-10-2012 10:47 PM #4
    a tuner bolt just has a slightly smaller diameter head for narrow spaces. dont listen to KAMPY bc hes obvi a fukn retart. some multi bolt wheels need tuner bolts or some redrilled rs's etc. its rare to find anything longer then 35mm long you might wana look into an RSD spacer/adapter where it bolts to the hub itself then is threaded for stock style lug use or run a studded adapter and get tuner lug nuts.
    these are prob wat ur looking for
    http://www.vrwheels.com/tuner-bolts-p-1741.html
    http://www.tulipcitywheels.com/tcwst...uct_list&c=657
    or use something like this with my second option.
    http://www.ecstuning.com/Volkswagen-...Spacers/ES333/
    "Remember its a VW..........its not supposed to be easy, just worth it."
  5. 07-11-2012 01:23 AM #5
    Quote Originally Posted by fukndubn96 View Post
    Thank you. More helpful.
