Results 1 to 5 of 5
Thread: looking for a replacement motor for my 1999 A-4 quatro 5 speed, any suggestions?
  1. 07-10-2012 03:53 PM #1
    I think I lost a crank bearing or something in the low end of the motor in my A-4, So now would be the time to upgrade, does anyone know of a compatable engine that I could put in place of the stock one, maybe a bigger one or one of better quality? Thank you for your help.
  2. Member SlowMotion's Avatar
    Jun 9th, 2002
    NNJ, NYC
    07-10-2012 07:06 PM #2
    I think you have to stick to the AEB engine. From 2000 they're equipped with Aww engine which is a bit different
    Sent from my PC36100 using Tapatalk 2
  3. 07-12-2012 07:39 PM #3
    Slowmotion, thank you for your help, is that a improved version of the motor in the 1999? Its a great car, I bought it for a couple thousand with 156K on it, I will shop around for the motor you suggested.
  4. Member demonmk2's Avatar
    Mar 18th, 2006
    Charlotte
    KITT 2000
    07-12-2012 07:57 PM #4
    you will want to find another AEB
    Any VWs made after 92 are usually only good for drive train donors.
    Jul 12th, 2011
    Mass
    2001 A4 1.8TQ AWM
    07-12-2012 08:24 PM #5
    Quote Originally Posted by demonmk2 View Post
    unless you are up to swapping out wiring harnesses and computer/controllers.
