VWVortex.com - 1.9L turbo diesel jetta question
    Results 1 to 10 of 10
    Thread: 1.9L turbo diesel jetta question
    1. 07-11-2012 12:13 AM #1
      Just bought this car, and I know nothing about it. I'm trying to replace the turbo and have no clue which one to buy. I plan on having a mechanic friend install it, but i need to know whether my 1998 diesel jetta has a ko3 or ko4 flange....does that make sense? I plan on trying to buying used. Which turbos from which cars would fit in mine? I'd appreciate ALL the help I can possibly get. Thanks vortex!
    2. Member burn_your_money's Avatar
      Oct 4th, 2004
      Bright, Ontario Canada
      6.9L F250
      07-11-2012 11:01 AM #2
      Is your car IDI or TDI? A picture of the engine bay would be good.
      Mar 31st, 2008
      PNW - Oregon
      07-11-2012 04:23 PM #3
      Quote Originally Posted by spry_chic View Post
      im not aware of a TDI/AAZ ever getting a K04..
      and a Gasser K03 wont work on a diesel. you need a diesel specific K03.
      is your car an AAZ car, or a TDI car?
    4. 07-12-2012 09:32 AM #4
      It's a TDI
    5. Member burn_your_money's Avatar
      Oct 4th, 2004
      6.9L F250
      07-12-2012 12:44 PM #5
      So it doesn't look like this?
      http://images.forum-auto.com/mesimages/150578/AAZ.jpg
      If it doesn't, you need a turbo off a AHU or 1Z engine. I think it's either a K03 or a GT15. There are piles of different style K03s. Make sure you get the right one.
      You may want to consider just getting it rebuilt. These guys come recommended
      http://www.vwdiesel.net/forum/index.php?topic=31392.0
      Those small turbos are hard to find in good shape used because they are almost always boosting.
    6. 07-12-2012 08:34 PM #6
      honestly, I don't even know where the turbo is in that picture....
    7. 07-12-2012 08:35 PM #7
      on top of the motor maybe??
    8. Member Rockerchick's Avatar
      May 10th, 2005
      Cary, NC
      '03 BMP 20th GTI, '84 TD Jetta
      07-12-2012 09:20 PM #8
      Behind the motor, by the firewall.
      Quote Originally Posted by TM87 View Post
      VW-making mechanics out of owners since 1957.
      The project - '84 Jetta 1.6TD
      The Wheelbarrow - '82 Rabbit Pickup
      Hers - '03 BMP 20thAE GTI
      His - '16 GLI SE
    9. Member burn_your_money's Avatar
      Oct 4th, 2004
      6.9L F250
      07-13-2012 12:10 PM #9
      Have your mechanic friend take a look at it and get the number off the tag on the turbo. It's on the compressor side and is usually blue or green. It's also usually covered in grease and oil.
    10. Member
      Mar 31st, 2008
      PNW - Oregon
      07-13-2012 12:37 PM #10
      just get your turbo rebuild.. its ALOT better than buying a used one, just to find out that IT NEEDS REBUILT AS WELL!!
      so, spend the $225 bucks, and send it to turboXS for a rebuild.. it will come back to you in BETTER than brand new condition..
