Results 1 to 10 of 10
Thread: New starter running constantly
    Sep 1st, 2009
    97 GTI VR6 01 GTI 1.8
    07-11-2012 05:57 PM #1
    I just installed a new starter and the thing wont turn off when I fire the car up. I pulled the power at the battery and when power is resupplied the starter motor starts running continuously.
    There isn't much to mess up on a starter install so I figured I'll summarize what I've been dealing with lately -
    I've had some start up problems and I settled on replacing the starter because it was making loud whirring noise on attempted starts and turn over. I also added another ground (from neg. terminal to sub frame) and cleaned the main ground points to the transmission.
    Still getting a blinking oil light and "on" battery light and the car wont turn over. After a minute and a few start attempts the car will turn over - sometimes it will run for about 10 seconds and quickly die and sometimes it runs true.
    What else could cause this? Can the whirring sound be coming from the transmission on start up?
    Any help would be greatly appreciated.
    Sep 1st, 2009
    07-11-2012 06:01 PM #2
    when I leave the key in the start postion the CEL will light up. but no codes when I run VAG com. When the car finally turns over, the CEL turns off.
    Sep 1st, 2009
    07-11-2012 07:04 PM #3
    would a bad ignition switch be a source?
    did I just put in a rebuild starter with a faulty solenoid?
  4. Member Slimjimmn's Avatar
    Apr 8th, 2006
    Rosemount, MN
    02 GTI 1.8t
    07-12-2012 09:25 PM #4
    if the starter keeps running (cranking) when the key is turned to on from start, most likely is a bad ign switch electrical portion. A $14 part at oreilly.
    the car is on an inclined driveway and up on jack stands in the front only
    VW's don't leak oil, they just mark their territory!
    Master L1 ASE certified
    Sep 1st, 2009
    07-14-2012 12:48 PM #5
    would the car have trouble turning over from a bad ignition switch as well?
    I replaced the starter with a new one and if is functioning well. Still having starting issues though.
    The car sounds like it wants to start but keeps clicking away.
  6. Member Slimjimmn's Avatar
    Apr 8th, 2006
    Rosemount, MN
    02 GTI 1.8t
    07-14-2012 02:54 PM #6
    sounds like the battery is going dead if its clicking.
    But if the starter keeps running after the car is started then either the ign switch is sticking or the starter solenoid is sticking.
    Sep 1st, 2009
    07-15-2012 10:09 AM #7
    solenoid was stuck open. swapped out for another successfully. still having turn over problems though.
  8. Member O_o's Avatar
    Nov 12th, 2009
    Vancouver, BC
    metropass
    07-15-2012 05:59 PM #8
    What does your coolant temp. gauge say?
    Sep 1st, 2009
    07-17-2012 10:30 AM #9
    I'm starting it cold so it's at ambient temperature.
  10. Member Slimjimmn's Avatar
    Apr 8th, 2006
    Rosemount, MN
    02 GTI 1.8t
    07-17-2012 08:40 PM #10
    so what your saying is:
    Now the starter works like it should.
    But now the car wont start at all (cranks and cranks)?
