The coil will work, however I'm not sure if it'll improve your setup.
#1
Hello, this is new for me. (and my english is not so good, i'm from Norway....)
But can I buy a MSD blaster coil on run it on my car?
1,8 16vT with Digifant 1 ECU.
-K24 KKK 7000 turbo
-440 ccm injectors
-3,5 bar fpr
-BKR7E spark plugs, gapped to 0,6mm
1,6 bar boost pressure
Today i've got 270whp / 347nm on the hubs with Rototest.
Is there anything from MSD product that can improve my setup?
And will the tachometer still work?
Thank you all for all answers I can get !
#2
#4
#6
The bosch setup is powerful, but the 6a will help with optimization of spark timing...
#7
If you want to use MSD 6A ignition amplifier,I would use the Blaster SS coil with this setup.
When mounting this you must remember to file down the distributor rotor to a specified width.
You also have to move the rotor a bit,cause the MSD 6A ignitor has a slight bit of delay when triggering the camshaft sensor.
#8
Resurrecting for clarification/more info....
I also have a 16vT running Digi1 (for now). I have a stage 5 chip from BBM and timing is set as per Bentley. She runs good. My distributor/cap/rotors/plugs are all brand new and plug wires don't arc.
I just picked up an MSD 6a (6200), and of course I would like to wire it up.
Will this be ok? I realize some MSD's have the ability to change timing under boost, and is this recommended or even required instead of the 6a? ...doesn't my ecu (chip) already handle that? If I don't need the MSD to change timing, is it ok to run the 6a for a better spark?
I understand how to wire it up, but do I need any additional MSD parts to get it to work? Will the tach work fine connected to the MSD's tach output spade, or do I need that MSD 8910 EIS tach adapter?
How much do I have to file down the rotor? Both sides?
and yes I assume I'll have to reset the ignition timing as per Bentley.
Any info/help is appreciated
#9
råååååååger... jeg kjører MSD blaster 2 på g60'nfunker fjell
-Dan
#10
8920 is the part number for the tach adapter
Sent from my SGH-T999 using Tapatalk 2
I have most wiring diagrams in PDF format for sale! $5
A1, A2, A3, A4, Corrado, New Beetle
Spoonfedtuning.com
#11
wow u made decent hp on that set-up about 315hp!! what chip are you running,and any other mods(internals or cams)
