VWVortex.com - what i get to have fun with
    Results 1 to 22 of 22
    Thread: what i get to have fun with
    1. Member paul610's Avatar
      Oct 26th, 2010
      610 pa
      1973 super beetle, 08 impreza
      07-12-2012 05:41 PM #1
      [IMG][/IMG]
      [/IMG]
    2. Member Quikg60dub's Avatar
      Apr 19th, 2007
      Mobile, AL (From the Pacific NW)
      1990 Corrado (G60 For Now)
      07-12-2012 05:55 PM #2
      Im not far behind you with tackling that rats nest....
    3. Member petethepug's Avatar
      May 25th, 2001
      So Cal
      Orig Owner 90 G60 & 02 Allroad 6Sp Man w/ 3rd Row Seat 07 3x White NB & 08 Yukon Denali XL to tow em
      07-12-2012 06:36 PM #3
      !! opɐɹɹoɔ ǝɥʇ!!ƃuıʇɔǝdsǝɹ !!!
      !! odarroɔ ǝht gnitɔepser !!
    4. Member paul610's Avatar
      Oct 26th, 2010
      610 pa
      07-12-2012 07:39 PM #4
      Quote Originally Posted by Quikg60dub View Post
      shall we have a race?
    5. 07-13-2012 01:11 AM #5
      I'm right there with ya man. I picked up a rado with a bunch of issues. Intermittent ignition, wipers inop, blah blah blah. I replaced the ignition harness so that's good now. Replaced the steering column cause the upper bearing was shot (bearings were falling out). I found a mouse nest under the dash too. I still need to figure out what's up with the wipers and I'm prob gonna pull out the alarm someone put in. Then I an reinstall the dash and start the reassembly of the interior process.
    6. Member HavokRuels's Avatar
      Jan 9th, 2011
      Rhode Island
      93' SLC 92' SLC 02' JETTA
      07-13-2012 08:45 AM #6
      I have been prolonging this project off for a while now.
      Guru Motorsports / europeein
    7. Member sdezego's Avatar
      Apr 23rd, 2004
      Hurricane Central FL
      '90 Corrado | '62 Harley Panhead
      07-13-2012 10:47 AM #7
      You haven't "owned" a Corrado until you have a pic like that
    8. Member veedubboostn's Avatar
      Dec 1st, 2004
      Syracuse, NY
      07-13-2012 11:06 AM #8
      Quote Originally Posted by sdezego View Post
      soo true
      20VT Corrado, then VRS Corrado while driving a 20V Jetta and 77' Vespa
    9. 07-13-2012 05:55 PM #9
      if i get to that point, im burning it.
    10. Member g60301's Avatar
      Aug 4th, 2011
      Maryland
      90' Corrado m62
      07-13-2012 05:58 PM #10
      Quote Originally Posted by wed3k View Post
      If your lucky it might burn itself for you
    11. Member paul610's Avatar
      Oct 26th, 2010
      610 pa
      07-13-2012 06:52 PM #11
      Quote Originally Posted by Damikestr View Post
      yeah I'm just going to gut the interior because some water go in there a while ago so i wanna clean it and I'm sure the previous owner did other stuff wrong this is just one of a long list of crap i have to do.
    12. Member smawgunner45's Avatar
      Aug 18th, 2005
      Columbus, Ohio
      93 Corrado VR6
      07-13-2012 08:17 PM #12
      Yup...looks familiar. I'm in the same spot. Swapping out an entire interior including dash. Fun awaits us all
      "I don't want to die at 90...I want to die DOING 90"!
    13. Member Deutschbag's Avatar
      Aug 15th, 2003
      Bay Area, CA
      93 Corrado SLC
      07-13-2012 09:01 PM #13
      Quote Originally Posted by g60301 View Post
      Haha well played.
    14. 10-03-2012 05:37 PM #14
      Just thought I'd let you guys know I got it back together and all functional. The wires on the A-pillar are from the old auto belts. I changed over to euro manual ones. I haven't put the headliner or pillar covers back on yet because I still need to do work on the sunroof.
    15. Member cata's Avatar
      May 19th, 2006
      Canada eh
      10-03-2012 06:04 PM #15
      that cleaned up real nice
      Quote Originally Posted by HavokRuels View Post
      Same. Going on two falls without heat now
    16. Member HavokRuels's Avatar
      Jan 9th, 2011
      Rhode Island
      10-03-2012 06:09 PM #16
      Like this??? I almost threw in the towel when I decided to tackle this
      Sent while sitting on my ass VIA my iPad
    17. 10-04-2012 08:28 PM #17
      Nice! Yeah I know how you feel. Haven't figured out how to get the relay/fuse panel to stay rotated in place. I have it on the hooks and the clips on it but it keeps rotating.
    18. Member paul610's Avatar
      Oct 26th, 2010
      610 pa
      10-04-2012 10:54 PM #18
      nice i just started really working on mine. the PO really likes to cut wires.
      i work on cars every day so when i comes to my cars im a slow worker lol but i have been doing a lot more lately. I got the short to power in the ignition, re wired the windows because the PO again didn't want to actually fix anything to he just hard wired them. sun roof and spoiler had some intermittent issues but thats fixed.
      after all this is done I'm sure its in need of a tune up and ill probably do the chain come winter
    19. Awaiting Email Confirmation FlatlanderSJ's Avatar
      Oct 3rd, 2007
      97 GLX, 92 LC3U Corrado VRT
      10-07-2012 12:44 PM #19
      there's holes in the brackets about an inch above the hooks that you have to seat the fuse box into for it to stay. make sure you get any wires that are pinched between the bracket and fuse box out for it to stay in place.
      And for anyone that has the dash out now, make sure you check that the radio harness is not chaffing against the metal support below the radio. There's a small constant power wire in the radio harness that is NOT fused, it just runs to the ignition switch and fuse-box un-fused. I would recommend adding some tape to the edge of the metal support and/or fusing that wire @ the ignition switch.
    20. Member paul610's Avatar
      Oct 26th, 2010
      610 pa
      11-11-2012 03:37 PM #20
      finally after way to long i got it all back together
      now to drive it and have some real fun
    21. Member mrbatavus's Avatar
      Nov 29th, 2008
      Ewing NJ
      2002 Chevy Trailblazer, 2002 Saturn L300, 2003 Saab 9-3 Linear
      11-11-2012 11:13 PM #21
      i was here not too long ago, just finished putting my dash back in after doing the heater core what a pita
    22. 12-08-2012 01:30 AM #22
      Well looks like I'll be pulling the dash back out on my project. Found that my heater core is bad. Boo
