Results 1 to 8 of 8
Thread: Sputtering on startup, fine after that...
  1. 07-12-2012 10:39 PM #1
    My VR6 sputters on starting after sitting awhile. It might take a number of turnovers to get going and then sputters for a few seconds, then once running is fine. It sounds/feels like a vacuum leak but then I would expect it to happen all the time. My other thought was a leaky injector. Car could probably use a tune up which I will do soon but typically runs well. Any one experienced this?
  2. 07-13-2012 05:17 PM #2
    Replaced all vacuum hoses and checked for other intake leaks. So far so good, I'll see if this continues.
  3. Member masterqaz's Avatar
    Oct 4th, 2007
    Oakville Ont
    94 JTI Vrt 60-1 .58ar exh obd2 440 racefile 20psi/meth
    07-13-2012 05:41 PM #3
    running rich on cold startups? - cts
    Forced convection.... Now we grillin.
    Some times she goes, some times she doesn't.... Way of the road
    Rem 870 super mag in max 4 camo for sale. Pm me
  4. 07-13-2012 07:10 PM #4
    Quote Originally Posted by masterqaz View Post
    Is that the blue one?
  5. Junior Member
    Jan 27th, 2012
    ft worth, tx
    07-13-2012 07:17 PM #5
    yes, two pin.
  6. 07-13-2012 09:06 PM #6
    Quote Originally Posted by thollandvw View Post
    yes, two pin.
    This little fella?
    Can I replace it with the engine cold or will I get coolant spilling out all over the place?
  7. Member youlostme21's Avatar
    Aug 12th, 2008
    SEPA
    98 S/C Vr GTi
    07-13-2012 09:17 PM #7
    Yes that lil guy, you'll lose a lil tiny bit of coolant but not too much.
    Sounds like an injector is leaking down into the cyl. If you have a fuel pressure gauge you can hook it up and see if psi drops over night. The system should hold atleast 30 in the line for startup. When the psi bleeds off you;ll get a long crank cause there is no fuel in the rail.
    It will also sputter casue of all the fuel that is now sitting in the cyl with the leaking injector.
    Any codes?
    You can pull the fuel rail out, leaving the lines connected, and turn the key to the RUN position a couple times to build up psi. Then lay down a piece of cardboard or paper towel under the injectors and see which one shows signs of fuel leaking out.
    If only I invested my money into something more practical then a VW....
  8. 07-13-2012 09:44 PM #8
    Quote Originally Posted by youlostme21 View Post
    Any codes?
    Thanks for the insight. No codes of course I will do as you mention. Changing the sensor is no biggie so I will do that and then check the injectors too. Car runs well otherwise so I want to get this looked after. I don't have a fuel pressure gauge but might have to pick one up.
