Results 1 to 10 of 10
Thread: Steering Angle Sensor Reset, is it a MUST?
  1. Member derekjl's Avatar
    Jun 23rd, 2006
    2007 VW GTI, 2007 Lexus IS250
    07-13-2012 12:08 AM #1
    I'm taking my car in for an alignment and doing some research on various new racks looks like they are now including a steering angle reset as the new "last step" of the whole process. I know this is possible to do with VAG-COM, but is it 100% necessary. My dealership says it is only necessary if the light comes on and there is a problem with the sensor itself. I've also heard that not resetting it can cause the steering wheel to be off center, as it is now. Give me some opinions please. Thanks!
    Need VAG-COM work in CNY? PM me!
    OEM+
    Mar 6th, 2002
    Morris Plains/Parsippany, NJ
    1998 GTI 2.0
    07-13-2012 06:52 AM #2
    Not sure if this is the correct forum for this question, but I've never done a reset when doing just a wheel alignment...
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  3. 07-17-2012 10:35 AM #3
    We call this "Steering Angle Sensor - Basic Settings" and "Steering Limit Stop"
    Activate needle illumination in ALL MICRONAS cluster since 2004 up to 2010. Activate STAGING for all NEC cluster since 2008 even if not availabe in adaptation chanel.
  4. Member derekjl's Avatar
    Jun 23rd, 2006
    07-17-2012 02:53 PM #4
    Quote Originally Posted by Spacewalker View Post
    Can it be done with the alignment computer or does it have to be hooked up to VAS/VCDS?
    OEM+
    Mar 6th, 2002
    1998 GTI 2.0
    07-17-2012 03:13 PM #5
    It must be done with VCDS.
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  6. Member derekjl's Avatar
    Jun 23rd, 2006
    07-17-2012 03:34 PM #6
    Quote Originally Posted by Anony00GT View Post
    Thanks. So, when would something like this be absolutely necessary?
    OEM+
    Apr 5th, 2010
    Blackheath, Sth London, UK
    '06 UK B6 BWA 3c0 SEL estate
    07-18-2012 04:11 AM #7
    Quote Originally Posted by derekjl View Post
    Did this procedure when changed control arm bushes (the ones within the large ally block)
    Steering wheel was off centre by about 5 degs before and occasional steering light fault flashed on at ign on, then off at startup. Even though I'd had the wheel alignment done which didn't put things back as they were
    Apr 5th, 2010
    09-18-2012 06:54 AM #8
    Quote Originally Posted by RichardSEL View Post
    Been two months and the steering light hasn't come on since using VCDS adaptation.
    And steering wheel has stayed centred
  9. Member derekjl's Avatar
    Jun 23rd, 2006
    09-18-2012 03:19 PM #9
    I managed to get access to a VAG-COM cable and I reset the wheel to where I visually saw 0 degrees. It didn't do anything to correct the tilted wheel. Guess I'll have to try another alignment.
    OEM+
  10. Member
    Jul 27th, 2007
    Ottawa, Canada
    07 Rabbit, 10 Tiguan, 1928 Chev, 02 Dakota
    09-21-2012 02:57 PM #10
    There is a lot of controversy and misinformation out there on this topic. i have heard a few stories, but if you think about it, if the car doesn't know where straight ahead is, how will the stability control know when you are off course. And our electric steering will also try an find zero as it's go straight position. Having the steering wheel straight is a function of the alignment, not the sensor. Assuming a good alignment having it want to go straight is a function of the sensor on the power steering. At our shop, what we have found is the best time to do it is when the alignment machine says the toe and thrust angle are correct and the steering wheel is straight. then we set the sensor at zero and all is good. You can't really find zero once it is off the rack. We tried and it does not work.
