VWVortex.com - Another cooling system question...
    Results 1 to 6 of 6
    Thread: Another cooling system question...
      Sep 26th, 2006
      13' Jetta SE W/Conv
      07-13-2012 12:48 PM #1
      So, I've recently started popping up a random P2181 performance malfunction in cooling system.
      It's so random and shows no signs of any other problems that I'm confused. Temp gets hot, stays exactly where it should be, 200. Never gets a tick hotter, or even close to above 200. Air works, heat works fine. No loss of power. It only seems to come on when I really put my foot down.
      I've done some searching and seen the Coolant temp sensor for ~36$ from ECS so I plan to replace that and hope it fixes it, but, I've read that improper coolant mixture can also throw this code? And if it was a thermostat sticking, wouldn't it take a long time to heat or overheat?
      I really don't want to get into replacing the thermostat and housing as I've seen that they're ~400$ job, and I really don't have that to blow. Thanks in advance.
      Jan 6th, 2012
      2006 VW Passat 3.6 VR6
      07-13-2012 04:58 PM #2
      Just a FYI, the temperature gauge isn't an exact readout as the dial shows. You get the same information as an "idiot light", where it only goes higher if the engine is severely hot.
    3. Member Tutti57's Avatar
      Jun 20th, 2011
      Rochester, NY
      2006 Passat 2.0T, 2003 Audi A6 3.0
      07-13-2012 09:02 PM #3
      There are also 2 coolant temp sensors.
      2006 Passat 2.0T Tiptronic | Unitronic Stage 2 | DG Springs | Newsouth Boost Gauge | BFI Tranny Insert | Rev D DV | BSH PCV fix | eBay Downpipe w/cat | Autotech Exhaust | DDM HIDs | Bentley Manual | VCDS - Car for sale! $6,000
      2003 Audi A6 3.0
    4. Member
      Sep 26th, 2006
      13' Jetta SE W/Conv
      07-14-2012 06:49 AM #4
      Anyone know anyone who wants to do a t-stat job and possibly a trans flush in the pittsburgh area? Cash & beer...lol. Also posted over in the regional forums, anywhere else you guys would suggest to look?
    5. 07-24-2012 01:56 PM #5
      Did you replace the temperature sensor with the part from ECS?
      I am having the exact same problem with p2181 coming up periodically.
    6. Member gilotin661's Avatar
      Aug 26th, 2005
      Bergen County
      13 JSW, 06 Rabbit
      07-24-2012 05:04 PM #6
      sounds like your thermostat is sticking....
      try cooling flush
