Check out Spockcat's site. You'll be able to get an auxiliary input with your current set up for very little $. Going aftermarket is expensive if that is all you are trying to get out of it. I've installed two of the audio adapters for the CD Nav unit and it takes about 15 minutes to do following the instructions on his site.
http://www.tm-techmark.com/tri.htm
