Results 1 to 5 of 5
Thread: Some custom bits
  1. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    '07 335i Sedan, '04 R32, '82 300D, '95 Jetta
    07-14-2012 01:13 AM #1
    Custom A/C, power steering and coolant bits for the R.
  2. Member Scrubbs's Avatar
    Mar 13th, 2006
    GB Maryland
    Mk2,s Mk3's
    07-15-2012 11:19 AM #2
    Hmm, never really thought about using AN fittings for the A/C. No orings, but would worry about leaks. Refrigerant is a gas alot of the time. So it can "seep" out of the smallest opening or void. Im interested in how it looks when done. Keep us up to date.
  3. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    07-15-2012 07:37 PM #3
    First time I have seen it as well haha. It has been a bit of a hassle as there is no out of the box way to attach barrier hose to SS 3/8 and 5/8 hardline. Which is the primary reason you don't see a ton of
    It. The aeroquip A/C stuff does not have a good rep and is heinously over priced.
    All the threaded fitting are o-ring so that takes care of any leaks there. The SS with my nice flaring tool makes a solid flare. I am sure it will seep out some, the question will be how much.
    I may even use some copper flare washers I have seen. The final step
    Is to have some steel barrier hose crimps welded on. I will bending the lines this week. I also had to have a trinary switch bung made in steel haha. I could probably use a more standard switch, just need to see if it is compatible with the VW signal.
    Quote Originally Posted by Scrubbs View Post
  4. Member gbisus13's Avatar
    Aug 16th, 2005
    Roc, NY
    86 Scirocco 16V, 04 Jetta 1.8BT, 89 944 S2
    07-16-2012 04:25 PM #4
    You might want to look into using swagelok fittings. We use them for high-pressure/high-temperature applications carrying all sorts of dangerous gasses (fuel cell R&D lab) and they have excellent sealing.
  5. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    07-16-2012 09:31 PM #5
    For the time being I am going to give the JIC fittings a go. With everything taped for o-ring adapters I have the tough part out of the way. I can try swagelock down the road if this fails.
    Thinking positive though. It should work... I hope.
    Quote Originally Posted by gbisus13 View Post
