well i've never really looked to test that.
i mean, normally DRL means it's a normal day with adequate lighting.
if it's overcast and raining, and you are having to use your wipers, naturally the drl will be off because you will need your headlights on (if it is set to AUTO, it will turn your drl off in most cases, even during the day, if it's dark enough)
