VWVortex.com - P1340 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
    Results 1 to 7 of 7
    Thread: P1340 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
    1. Member Stoddart's Avatar
      Sep 26th, 2007
      Stillwater, MN
      MKIV '00 VW GTI GLX VR6
      07-14-2012 09:55 AM #1
      Ok, mechanically the timing is perfect. The crank pully and block timing marks are aligned and the cam lock easliy fits is in. new chain kit and the slack is tight in the front and loose in back with the tensionor bolt out. the intermediate shaft gear has slight wear. swapped both crank and cam sensers. still no luck.
      any ideas?
      '92 Audi CQ: Sold
      '93 90 CS FWD V6 12v (commuter): Sold
      '00 VW GTI VR6: Sold
    2. Member masterqaz's Avatar
      Oct 4th, 2007
      Oakville Ont
      95 gti 24vt toy, 04 tdi golf economy, 94 gti 12vt sold
      07-14-2012 08:17 PM #2
      Bad ground or ecu
      diesel life cause cold feet are fun....
    3. Member Stoddart's Avatar
      Sep 26th, 2007
      Stillwater, MN
      10-04-2012 11:53 AM #3
      Its been flashed or chipped... taken it to a shop to see if I can re program to oem spec.
      '92 Audi CQ: Sold
    4. Member Davespeed's Avatar
      May 4th, 2004
      The VR farm.....
      10-08-2012 01:20 AM #4
      Does it run?
      I sell Rotiforms and Airlift products......
      I wrench on VW's and Audi's.......
      AudiHendersonParts discount OEM Audi and VW parts
    5. Member Stoddart's Avatar
      Sep 26th, 2007
      Stillwater, MN
      10-08-2012 10:15 AM #5
      Idles fine, but at low rpms, you notice the difference when acceleration. if I run 'er above 3200 its sounds fine. I might have a problem with the intake manifold shifter rod tough, bad bushings. That is only one symptom, though. After long drives shes raspy.
      did have it flashed back to oem.
      update: http://forums.vwvortex.com/showthrea...rs-for-the-afp
      '92 Audi CQ: Sold
    6. Member Davespeed's Avatar
      May 4th, 2004
      The VR farm.....
      10-08-2012 11:30 PM #6
      If it ran fine prior to the downshift mishap, then your timing is incorrect after your repair. You need to go over the DIY and verify your timing marks again. The cam timing can be incorrectly set by 180 degrees via cam lock method. The crank pulley TDC mark and cam lock are not fool proof. The notches on the cam gears need to be on top.
      http://forums.vwvortex.com/showthrea...s-on-a-12v-VR6
    7. Member Stoddart's Avatar
      Sep 26th, 2007
      Stillwater, MN
      10-09-2012 11:02 AM #7
      if I am correct, if that were the case, I'd be missing on half my cyclinders
      '92 Audi CQ: Sold
