Results 1 to 6 of 6
Thread: Scan inside, Need help determining where to look.
  1. Senior Member CapeGLS's Avatar
    Aug 2nd, 2002
    Connecticut
    01 Golf GLS 1.8T, 02 Jetta WGN 2.0, 11 JSW 2.5SE (Wifes)
    07-14-2012 10:27 AM #1
    Some background, car has had an intermittent misfire, so this year I took out the ignition harness and replaced it with one that was not broken and repined it into the factory harness. So I put the car back together and scan it and noticed some new codes.
    The car currently doesn't start (tracking down an issue with my fuel pumps not priming or coming on when the key is in the ON position.) Fuel Pump terminal 87f (connected to relay 409) has 12v when the door is opened, but quickly drops to 0 and does not return when the key is turned.
    I also do not have spark to the coil packs, but have 12v at the hot wire, but the ignition wire on the coil reads .21 when trying to start.
    (seems low)
    If its RED those are the codes I need some assistance with.
    Seems like 16706 could cause no spark, so I wonder if I have the speed sensor incorrectly plugged into something else.
    Thank you.
    Saturday,14,July,2012,10:10:27:12400
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 1J - VW Golf/Bora IV
    Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
    76
    Mileage: 152110km/94516miles
    Address 01: Engine Labels: 06A-906-032-AWW.lbl
    Part No: 06A 906 032 DL
    Component: 1.8L R4/5VT G03 0003
    Coding: 07500
    Shop #: WSC 77876
    VCID: 6BDE2DF7199ED11
    XXXXXXXXXXXXXXXXX XXXXXXXXXXXXXX
    9 Faults Found:
    16486 - Mass Air Flow Sensor (G70)
    P0102 - 35-10 - Signal too Low - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-10 - - Intermittent
    16685 - Cylinder 1
    P0301 - 35-10 - Misfire Detected - Intermittent
    16688 - Cylinder 4
    P0304 - 35-10 - Misfire Detected - Intermittent
    16686 - Cylinder 2
    P0302 - 35-10 - Misfire Detected - Intermittent
    16497 - Intake Air Temp. Sensor (G42)
    P0113 - 35-10 - Signal too High - Intermittent
    18012 - Internal Control Module
    P1604 - 35-00 - Output Driver IC Error
    17972 - Throttle Actuator (J338)
    P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
    16706 - Engine Speed Sensor (G28)
    P0322 - 35-10 - No Signal - Intermittent
    Readiness: 0000 1100
    Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
    Part No: 1C0 907 379 D
    Component: ASR FRONT MK60 0103
    Coding: 0021505
    Shop #: WSC 00000 785 00200
    VCID: 2B5EEDF7891E111
    2 Faults Found:
    00283 - ABS Wheel Speed Sensor; Front Left (G47)
    012 - Electrical Fault in Circuit - Intermittent
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 6Q0 909 605 F
    Component: 07 AIRBAG VW6 0202 0003
    Coding: 12343
    Shop #: WSC 00000
    VCID: 3A70D8B32644B89
    5 Faults Found:
    00588 - Airbag Igniter; Driver Side (N95)
    32-00 - Resistance too High
    01217 - Side Airbag Igniter; Driver Side (N199)
    01218 - Side Airbag Igniter; Passenger Side (N200)
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
    32-10 - Resistance too High - Intermittent
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
    Part No: 1J0 920 905 J
    Component: A4-KOMBIINSTR. VDO V09
    Coding: 07232
    Shop #: WSC 00000
    VCID: 2E58E4E3EA0C649
    Subsystem 1 - Part No: IMMO
    Component: IDENTNR: VWZ7Z0Y2915313
    IMMO-IDENTNR: VWZ7Z0Y2915313
    1 Fault Found:
    01316 - ABS Control Module
    49-10 - No Communications - Intermittent
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 00000
    VCID: F0E4BA9BB0B8B29
    1 Fault Found:
    Address 46: Central Conv. Labels: 1J0-959-799.lbl
    Part No: 1J0 959 799 AJ
    Component: 60 Zentral-SG Komf. 0001
    Coding: 04096
    Shop #: WSC 00000
    VCID: 8608FC43A23C8C9
    Subsystem 1 - Part No: 1J1959801C
    Component: 60 Tõrsteuerger. FS0002r
    Subsystem 2 - Part No: 1J1959802D
    Component: 60 Tõrsteuerger. BF0002r
    Subsystem 3 - Part No: 1J4959811C
    Component: 60 Tõrsteuerger. HL0002r
    Subsystem 4 - Part No: 1J4959812C
    Component: 60 Tõrsteuerger. HR0002r
    No fault code found.
    End ---------------------------------------------------------------------
    Chamber: My Wheels Rub on the Inside|Forgeline Wheels|WRDusa.com|
    FlickR
  2. Senior Member CapeGLS's Avatar
    Aug 2nd, 2002
    Connecticut
    07-15-2012 12:30 PM #2
    Anyone?
    FlickR
  3. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    '10 Skoda Octavia vRS Combi / '67 Ford Mustang Conv.
    07-15-2012 04:03 PM #3
    What would concern me most is the P1604 for now. This may very easily be the culprit for your issues and since that code is not intermittent but rather static I would try and source a different ECM for testing purposes. It doesn't need to be fully compatible just to test for starting troubles, even with the immobilizer not matched you should see it crank and run - all the immobilizer will do is shut it off 1-2 seconds after it started.
    P.S.: Please do not bump topics, it will not make people reply to you any fast and a topic with 0 replies in the forum overview will give you more clicks than one with 1 or more posts. Meaning, with a 0 replies topic we often feel more obligated to reply... Aside from that bumping topics may be considered rude by some, especially on weekends. Every understands that you're issues are more or less urgent but you're not being ignored intentionally.
  4. 07-15-2012 11:11 PM #4
    Your in need of a firmware update which may correct the DTC and it may not.
    You could send me your ecu to check out and if repair exceeds the cost of replacement, I can data transfer the immobilizer and get you a reman or new unit.
    In stock please let me know.
    Vortex RT discount applies.
    Please verify all fuses and try disconnecting the OXS sensors to see if this current track is shorted for the heaters causing an issue.
    Jack Shapiro E.P.E. VAS>ASE Extern VST-3/1 LAB (TECH INQUIRIES ARE TO BE IN WRITING )
    7076062 NYS DMV SAE>NASTF>VW-Audi GEKO Authorized
    European Parts Emporium/Performance --- Immobilizer Solutions LLC --------
    Postadresse: 1001 State Route 17K Montgomery New York 12549 USA
    vwemporium@aol.com -845-457-9808 TEL 9AM-5PM --------TAKE CONTROL OF WHAT YOU OWN!!!!!!
  5. Senior Member CapeGLS's Avatar
    Aug 2nd, 2002
    Connecticut
    07-16-2012 06:45 PM #5
    I have 3 other ECU's that I have in my garage, all are in working order.
    Can a wiring short, or an incorrectly pinned wire cause this short? Could it be a data exchange fault and not a hardware issue (ie: able to be cleared vs:ecu being fried?)
    FlickR
  6. 07-16-2012 07:41 PM #6
    More then likely but also could be a hardware issue or combination such as cause and effect from cause.
