Page 1 of 2 1 2 LastLast
Results 1 to 35 of 36
Thread: Winterization In the North
  1. n00b
    Jun 21st, 2012
    Michigan
    1969 Volkswagon Bus
    07-14-2012 03:45 PM #1
    I am beginning to prepare my VW bus for winter storage in a unit. I have never done this before and am wondering if there is anything specific I should do or what exactly I need to cover my bus with?
  2. 07-14-2012 03:54 PM #2
    As its July I can't help but think:
  3. Geriatric Member ATL_Av8r's Avatar
    Oct 17th, 2002
    Gapiana
    07-14-2012 04:05 PM #3
    Your best bet is to put it in a climate-controlled storage unit with 24 hour security and appropriate facility insurance. Like this:
  4. Member davidraeside's Avatar
    Sep 8th, 2004
    Ontario, Canada
    07-15-2012 11:18 AM #4
    Yes.
    Current: 2006 Acura CSX
    Gone: 2004 Jeep Liberty Renegade (375,000 kms), 2007 VW GTI (BMP), 2001 VW Jetta Wolfsburg Edition, 1994 Ford Ranger (calipso green), 1987 Jeep YJ
  5. Member GolfTango's Avatar
    Feb 15th, 2001
    Not Fancy CT
    09 Mazda5 GT, 09 Saturn Aura XE
    07-15-2012 11:48 AM #5
    I'd cover it with fire to keep it warm
    My flickr
    Me
    The best way to give advice to your children is to find out what they want and then advise them to do it. - Harry S. Truman
  6. Member
    Feb 6th, 2007
    CT
    2002/VW/Golf 2.0
    07-15-2012 11:53 AM #6
    Feed it milk and nutrients. I'll be alright..
  7. Member mobile363's Avatar
    Oct 13th, 2003
    2012 Kia Rio5 6MT, 2012 Dodge Caravan
    07-15-2012 11:54 AM #7
    chances are it has survived many winters outside to its own devices. Another year wont hurt. Unless this is a show quality bus, just park the thing outside.
  8. Junior Member
    Aug 26th, 2010
    Prince George B.C. Canada
    83 Rabbit GTI, 81 Rabbit pickup, 86 GMC Pick up, 85 Dodge W150, 57 Dodge PowerWagon, 56 VW SingleCab
    07-15-2012 12:00 PM #8
    Make sure the antifreeze is good and strong don't want to crack the block when the temps get cold
  9. Member eunos94's Avatar
    Mar 17th, 2002
    Northeast Ohio
    Yellow 1970 Beetle & Yellow Rush 2012 Beetle 2.5L Tiptronic
    07-15-2012 02:58 PM #9
    Quote Originally Posted by BEATER_BUG View Post
    hahahahahaha.... wait you're serious????
  10. Member
    Jan 8th, 2002
    Ontario
    2006 Pontiac Vibe, 2011 Toyota Venza
    07-15-2012 03:36 PM #10
    Our lakes only freeze within the top 2~3' of surface. Below that temperature level remains around or above freezing. That is where I have stored my boat for the past three winters. I just check on it a few times throughout the winter to make sure the anchor is still firmly attached. I suggest you sink the bus, just be sure you use the appropriate anchor for the lakebed.
    Chris
  11. 07-15-2012 03:37 PM #11
    Put sta-bil in the gas and top off the tank, I would recommend driving it a bit to ensure you get that gas distributed.
    Wash the car before you store it. Cover it in storage.
    Change the oil before you store it.
    Do not use the e-brake for long term storage.
    Disconnect the Battery.
    Spread mothballs around it to prevent critters.
    Consider putting it on jackstands to keep the tires from flat-spotting
    ^note that a few of these can be omitted if you have continued access to the car and can start/drive it from time to time. Firing it up and running all the systems (heater, AC if equipped, etc) is best if possible. Temperature control is also nice, again if possible.
  12. Member Broduski's Avatar
    Nov 18th, 2008
    Barbeque Capital of the World, NC
    Old Stuff.
    07-15-2012 04:21 PM #12
    Quote Originally Posted by I<3MyBus View Post
    It's July. Are you storing it in the arctic circle that you need to start this early?
    A Ford, two Dodges, A Volvo, And a #GEH
  13. Member emmettlodge's Avatar
    Nov 7th, 2007
    Ohio
    2012 Tacoma 4x4, 2010 Tacoma 4x2, 1990 E30
    07-15-2012 04:24 PM #13
    You shouldn't need to do anything special to store a vehicle over the winter except disconnect the battery and take it inside.
    Next stupid thread.
    All rights reserved. No fur-bearing animals were harmed during the creation of this post. Caution: May cause irritability, sleeplessness or warts after prolonged reading. May cause some laboratory rats to rip through their cages, fly across the room and brutally murder hundreds of innocent people. Not to be combined with other posts except under the advice of a physician.
  14. Member Hawk's Avatar
    May 7th, 2010
    Toronto, Canada
    07-15-2012 04:27 PM #14
  15. Banner Advertiser chris@revotechnik's Avatar
    May 17th, 2007
    Summit Point, WV
    X,80,X,X,98,00,X,06,12
    07-15-2012 05:39 PM #15
    Quote Originally Posted by tasty danish View Post
    Starting an engine for no reason is the WORST thing you can do it.
    Unless you plan to get it up to operating temp and keep it their for an extended period of time you WILL do more harm then good.
    Stored vehicles should NOT be started for the hell of it.
  16. 07-16-2012 10:59 AM #16
    You do not want to start the car unless you are taking it out for more than a spin around the block. This will create moisture within the cylinders and exhaust.
    Stabilize the gas, park on plywood, disconect battery, stuff rags in the exhaust pipe, use peppermint oil in the engine bay and interior(apparently works better than mothballs. Smells better too).
    Park it and walk away until it is time to take it out in the spring.
    2009 Mazda 6 GS V6
    2008 Suzuki Hayabusa
  17. Member clutchrider's Avatar
    Dec 10th, 2010
    Connecticut
    2012 GLI
    07-16-2012 11:09 AM #17
    Post on winterizing in the North when car is actually going to be stored in a garage
    Put car on jack stands, remove tires, add car cover, close garage door.
    Came for someone looking for information on winterizing their car to be "driven" in the North.
  18. 07-16-2012 11:11 AM #18
    Pretty much what I do to a T when I put my Si away for the winter.
    I use the Ignore function on here liberally. Just an FYI.
  19. Member seadoo2006's Avatar
    Feb 4th, 2008
    Cleveland, OH
    04 Audi S4 Avant 6MT
    07-16-2012 11:18 AM #19
  20. Member mhjett's Avatar
    Oct 16th, 2000
    Northern Virginia
    2008 VW Jetta SE
    07-16-2012 12:10 PM #20
    Ground-breaking question, good sir. I'm sure that question has never before been asked in this car forum.
    1995 VW Jetta GLX VR6 [07.2003 - 03.2012]
  21. Member
    May 26th, 2006
    Chattaboogie, TN
    2011 GTI #yolo
    07-16-2012 12:32 PM #21
    Quote Originally Posted by cstraw View Post
    Our lakes only freeze within the top 2~3' of surface...That is where I have stored my boat for the past three winters...I suggest you sink the bus, just be sure you use the appropriate anchor for the lakebed.
    Call To Order Pizza But Too Shy To Answer The Door When It Arrives Crew
  22. Junior Member
    Aug 26th, 2010
    07-16-2012 12:59 PM #22
    Quote Originally Posted by eunos94 View Post
    Dead serious, proper antifreeze composure is a must in all air cooled Volkswagens
  23. Geriatric Member AKADriver's Avatar
    Nov 20th, 2001
    Unreal VA
    NB Miata
    07-16-2012 01:01 PM #23
    Coat the entire car in a generous layer of cosmoline, then bury it in peat.
    I don't practice llanteria
  24. Member
    May 26th, 2006
    Chattaboogie, TN
    2011 GTI #yolo
    07-16-2012 01:09 PM #24
    Protip: sarcasm in this forum is pointless. You can say the most idiotic things, trying to be funny, and half the forum won't understand and send you a constant stream of .
    edit: unless your sarcasm is in the form of a HILARIOUS image macro lol!!!
  25. 07-16-2012 01:36 PM #25
    Quote Originally Posted by chris@revotechnik View Post
    Did I say, "start engine and jerk off for 5 min" ???
    What reason do you ever have to start an engine? For the hell of it? What does that even mean?
    I said run all systems. This implies that you get it up to temp and take it through its paces.
  26. Banner Advertiser chris@revotechnik's Avatar
    May 17th, 2007
    Summit Point, WV
    07-16-2012 01:39 PM #26
    Then your car is not in storage and you don't need to do any of the other things you said.
    Park car don't start it until you plan to USE it again.
    Without actually taking the car out getting EVERYTHING up to full temp including oil and keeping it there for an extended period of time you are doing more harm then good. During winter months this may not even be possible to do without flogging the hell out of the car.
    What purpose does that serve a car in storage?
    Sorry you were wrong get over it.
  27. 07-16-2012 05:05 PM #27
    Dude did you even read either of my posts?
    It's like a friggen echo in here.
  28. Banner Advertiser chris@revotechnik's Avatar
    May 17th, 2007
    Summit Point, WV
    07-16-2012 05:16 PM #28
    I did, you are still wrong, your car is not in storage then it is just parked in between uses. Who posts asking what to do with their car between uses? You don't winterize a house and come flush the toilet every few weeks...
    You said firing it up is best if possible.. no firing it up is the WORST possible thing you can do. What purpose does going and driving a car that is stored serve?
    Running all the systems in no way implies run it until your oil is up to temperature of an extended period of time to make sure you burn off all the water you just mixed into your oil for no damn reason because some guy on the internet told to start the car every so often.
    Why are you not crying about the other guy who told you that you were completely wrong as well?
  29. Member mhjett's Avatar
    Oct 16th, 2000
    Northern Virginia
    2008 VW Jetta SE
    07-16-2012 05:30 PM #29
    This is true. Cold starts are the worst on engines, especially COLD winter starts on engines that have been sitting for weeks or months.
    tasty danish - you are wrong. You either store the car and don't run it, or you aren't storing the car.
  30. 07-16-2012 06:47 PM #30
    Don't tell me what I implied. You can't even open the thermostat if you don't fully warm the car up, so you have to to fully exercise the coolant system, and many oil systems have thermo-plugs as well. So yes, that's what I was implying.
    No one else told me I was "completely wrong" and I never said anything about just "firing it up." I said run the car from time to time if possible and you all jumped on my ****. I never disagreed with you. You're just being abrasive just to be abrasive.
    When did I ever say to just fire the car up real quick and shut it off before it warmed up? I make 8 points, you take issue with one, that you misinterpreted and now I'm 100% off?
    Better yet, don't answer that, I'm done. This devolved into a bitch-fest way too fast.
  31. 07-16-2012 07:29 PM #31
    All I do is pull my car in the garage, disconnect the battery, add sta-bil and go inside. My garage isn't heated but it likely doesn't get as cold as a storage unit since it is attacjed to the house.
    On a nice winter day I might want to go for a drive and knowing I had to take off jackstands would ruin that real quick.
  32. 07-17-2012 07:37 AM #32
    Hi, I'm the other guy, and yes, you are completely wrong if you think it is best to start a stored car. First off an air cooled motor does not have a thermostat. That is not where the moisture comes from. Moisture is a byproduct of the combustion process. Even if you start the car and warm it up to operating temperature, you will get moisture buildup in the cylinders and exhaust.
    The rest of your steps were good, but just park it and forget it.
    2009 Mazda 6 GS V6
  33. Member barry2952's Avatar
    Jun 13th, 2007
    Farmington Hills, MI
    07-17-2012 07:51 AM #33
    This thread is ****ing hilarious. With rapid weather change I'll be driving my convertibles mid-winter in Michigan.
    Just park it. Nothing more to be done. You make it seem like it's the ****ing North Pole.
    Garmin Is My Pilot.
  34. Member mhjett's Avatar
    Oct 16th, 2000
    Northern Virginia
    2008 VW Jetta SE
    07-17-2012 07:53 AM #34
    No, actually I also told you you're completely wrong. So did karl_1052.
  35. Member barry2952's Avatar
    Jun 13th, 2007
    07-17-2012 08:17 AM #35
    Not a bad idea, but unnecessary for 3 months
    Why? It's easier to hose dust off than repair the scratches from the cover.
    Again, an unnecessary step.
    Why? He's talking about winter storage, not a time capsule.
    Unnecessary. If your battery goes dead then you have an electrical problem with your car.
    That only keeps away people.
    Unnecessary, they turn round again in a few minutes.
    /\ Starting a car unnecessarily is the dumbest thing I've ever heard. If you're driving it from time to time then it's really not storage.
    Garmin Is My Pilot.
