Results 1 to 4 of 4
Thread: Please Help!
  1. n00b
    Jul 14th, 2012
    Washougal, WA
    84 MK1 GTI & 06 Pontiac GTO
    07-14-2012 09:13 PM #1
    I just bought a 84 GTI less than four hours ago. One of the problems I had was the speedometer wasn't working. So I bought a new cable, but when pulling the old one out the plastic gear broke off, falling into the transmission. I've tried fishing it out with my fingers and using an extended grabber, But I can't feel it or see it. I am pretty sure it's at the bottom of my transmission. Do I have to unbolt my transmission or is there a way around this?
  2. n00b
    Jul 14th, 2012
    Washougal, WA
    07-14-2012 11:00 PM #2
    **** it. I am running it with the nylon thread in there and all. Wish me luck.
  3. 07-26-2012 10:42 PM #3
    Quote Originally Posted by cedge88 View Post
    Good Luck!
  4. Member 8v-of-fury's Avatar
    Jul 14th, 2008
    Central Ontario, Canada
    Because MK1
    08-12-2012 06:41 PM #4
    The hardened gears will chew it up, no problem.
    As you've found it has worked out fine for you.
