Results 1 to 28 of 28
Thread: Leaks
  1. Member germanbycar's Avatar
    Apr 27th, 2009
    Gainesville, FL
    P51 Mustang
    07-14-2012 10:25 PM #1
    How many of you guys have small leaks?
    My rear bags leak probably 5psi over 20min of driving. No big deal, I just add some air and adjust.
    Not sure if it's worth re doing my rear fittings.
    Anyone else just deal with it?
    Paint it black and take it back.
    Shawn's Speed Shop
  2. Member rgarjr's Avatar
    May 19th, 2012
    Los Angeles area
    1998 Lexus GS300
    07-14-2012 10:48 PM #2
    that sounds like a large leak. I would try to find it. Does it dump all overnite?
    Aug 19th, 2011
    Birmingham, AL
    MKV GTI
    07-14-2012 11:08 PM #3
    Yea... That is a large leak. My air tank will empty to 1/4th pressure from full when left over night (and I know which plug is leaking, just haven't fixed it yet) but my bags don't leak at all, even over night
  4. Member germanbycar's Avatar
    Apr 27th, 2009
    Gainesville, FL
    P51 Mustang
    07-14-2012 11:38 PM #4
    Ahhhh ok. Ill re do the fittings on the rears
    Shawn's Speed Shop
  5. Member germanbycar's Avatar
    Apr 27th, 2009
    Gainesville, FL
    P51 Mustang
    07-15-2012 02:07 AM #5
    Went and re did them. Problem solved.
    Shawn's Speed Shop
  6. Member gtipwnz's Avatar
    Jun 6th, 2010
    Wisconsin
    Mk3 Jetta Wolfsburg, Mk6 GTI (sold)
    07-16-2012 06:45 PM #6
    I lose about an inch of height on my rear left corner over 24 hours, but it doesn't bug me and it hasn't gotten worse in a year.
  7. Member DoctorDoctor's Avatar
    Oct 18th, 2006
    Bay Area, California
    06 GTI, 04 Jetta (Gone)
    07-16-2012 07:26 PM #7
    To the OP, glad you got it fixed
    In the cold, my tank loses a couple of PSI, but now in the summer my pressures stay where I leave them
    Tomas Sport Tuning + Bag Riders = BAGS & BBS RS
  8. Junior Member
    May 12th, 2012
    Concord, NC
    07 GTI
    08-31-2012 04:32 PM #8
    Rather than making a new thread. Bump
    I have been trying to track down a small leak in my tank (~15 PSI over night). And I just can't seem to locate it. I've sprayed all of my fittings with soapy water and don't see any bubbles. Was wondering if there is something that I could put in my tank that will come out of the leaks so I could finally hunt this down. I have a VU4 manifold with the 5 gallon aluminum skinny tank with 2 SMC water traps. Don't want any of that to get damaged obviously. Any help is appreciated, Thanks.
  9. Member dubb34r's Avatar
    Apr 3rd, 2011
    ATL
    Mine: Bagged TR '11 GTI His: '08 WRX
    08-31-2012 07:42 PM #9
    Quote Originally Posted by TuckinLow View Post
    Are you sure the leak is in the tank and not between the line going to your manifold? I installed an SMC check valve today due to a similar situation as yours. After a few hours it seems the leak was not in my tank but the manifold. Won't know for sure till I let the car sit overnight.
    BAG RIDERS | APRStage 2
  10. Junior Member
    May 12th, 2012
    Concord, NC
    07 GTI
    08-31-2012 08:37 PM #10
    Quote Originally Posted by dubb34r View Post
    Do you have the VU4 manifold? am not sure how prone to leaking they are, but I did make sure the line going into the manifold was cut straight and set all the way into the PTC.
  11. Member afunnysmell's Avatar
    Dec 16th, 2010
    Atlanta
    Bagged '13 Golf R
    08-31-2012 11:51 PM #11
    Quote Originally Posted by germanbycar View Post
  12. Member dubb34r's Avatar
    Apr 3rd, 2011
    ATL
    09-02-2012 12:51 PM #12
    No I've got the V2 manifold.
  13. Member DGK_KGD's Avatar
    Nov 11th, 2010
    Alaska
    03 JB #2028
    09-03-2012 06:01 PM #13
    one of my supply lines going into my VU4 manifold is pushing it at just the right angle to cause it to leak slowly overnight.... so instead of rerunning an entire line im just waiting for a PTC union to extend the line a little and allow it to go into the mani straight on... so i hope this is the problem
    Quote Originally Posted by scirockalot8v View Post
    Plastidip the world.
  14. Junior Member
    May 12th, 2012
    Concord, NC
    07 GTI
    09-03-2012 09:03 PM #14
    I just went out today and had a heyday with some soapy water. I sprayed every fitting twice. My last problem was a leaky water trap at the bottom due to corrosion had that replaced and I checked it again just to make sure and the new trap is leaking the same exact way. So I drained the tank and retightened that trap so we'll see how that goes. Hopefully it seals this time since it is a brand new trap.
  15. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    '08 GTI, '12 Beetle, '91 Passat
    09-03-2012 09:58 PM #15
    No tank leaks. I do have a very slight leak in one of my rear bags though. One day when I'm not lazy I'll redo the fitting and make sure its properly sealed
    // DROP // DRAG // DESTROY // beer
    // Open Road Tuning
    Instagram: @bryangb
    bags and wheels = build thread
  16. Member Andy P's Avatar
    Jan 6th, 2007
    Cleveland, OH
    09-04-2012 07:57 PM #16
    Quote Originally Posted by bryangb View Post
    x2 pass rear - but if I leave mine air'd up over night that one bag will be air'd out... need to fix that before h2o
    My 06 GTI | IG: andyp666
    Quote Originally Posted by Thagodeus View Post
    Of course by i just pretend that andy waves a magic wand and everything is happily ever after
  17. Member dubb34r's Avatar
    Apr 3rd, 2011
    ATL
    09-06-2012 07:13 PM #17
    Instead of clogging up this thread
    http://forums.vwvortex.com/showthrea...0#post78878730
    I'm moving my conversation over here.
    Quote Originally Posted by Piso View Post
    Did you use tape or loctite?
    I've used both. Tape the first time, second time another brand like loctite, then back to tape this time around the pink teflon. Ordered Loctite 545 last night. Planning on doing the soapy water *again to see what I find this time around.
    Quote Originally Posted by Squirrel Nuts View Post
    It more than likely didn't gain any air. There's more weight on that corner because of the loss of air in the other corner so the pressure becomes higher. If you were to air up the corner that leaked it would probably go back to where it was before you left it.
    Don't know about that since the difference in PSI is more than 10. But mainly car was parked on my driveway which is pretty steep. Front of the car was more on the decline and the rear on the more leveled section... so the cars weight is much more up front.
    It may have been asked already but did you cut the end of the airlines evenly and cleanly?? If they're not even, you'll have all kinds of air leak out of there. FWIW, I had an issue with a leak and asked Air Lift for some extra 90 degree PTC that go in the manifold and it fixed my problem. I'm sure they'll get you squared away though.
    Yeah I've cut the lines numerious times now. I did have a few of them that weren't as evenly as I had originally thought. I have the same elbow PTC you're talking about that connect the lines to the manifold. I've always tried not using those at all, same results. Will mentioned I could also have a very small pinhole in the tank itself.
    Obviously I'm doing something wrong. It's mind boggling I've recut, refitted everything 3 separate times now and I can't get a single bag to hold air?
  18. Member dubb34r's Avatar
    Apr 3rd, 2011
    ATL
    09-06-2012 11:46 PM #18
    Looks like my fittings had been turned way too tight during the initial install. Possibly to the point of damaging some if not all of them. Running out tomorrow to buy all new fittings for the tank and start from there.
  19. Member
    Mar 28th, 2007
    iowa
    07 uni black rabbit
    09-07-2012 11:06 AM #19
    my pressure slowly drops about 10psi from max fill and then seems to stabilize. immediately loses a couple (no big surprise there, valves aren't instantaneous) but then it works its way down from 173 to the mid-160's within the hour. held there for a few hours until I started playing with it. this is with an ob2 compressor and autopilot v2 manifold, running in manual mode with just the fronts. bags hold pressure like a champ, and only had one obvious tank leak that I already tended to. maybe the Loctite is still working its way around to make a positive seal since things are still fresh.
  20. 09-19-2012 09:37 AM #20
    I lose about 100lbs from my tank overnight. just a couple like 3lbs from 2 of my stuts. I sprayed every port of my tank with soapy water and could not any bubbles. where else do i look?
  21. Member
    Mar 28th, 2007
    iowa
    07 uni black rabbit
    09-19-2012 10:55 AM #21
    Quote Originally Posted by 20vtVdubb View Post
    bad manifold? what setup are you running? the 3 lb change is more than likely just lower air temp. PV=nRT (ideal gas law). n and R are conststants and your volume is essentially constant, so temp will directly affect pressure.
  22. 09-19-2012 05:55 PM #22
    Quote Originally Posted by iowarabbit View Post
    v2 manifold
  23. Member
    Mar 28th, 2007
    iowa
    07 uni black rabbit
    09-20-2012 01:34 AM #23
    did you check the water trap and compressor junctions too? trap drain also may not be fully sealed. i'd honestly try it w/o the trap for a couple days and see if that solves the problem, then call air lift if there's no change.
  24. 09-20-2012 10:33 AM #24
    I check the fitting around the comp and trap but not the bottom of the trap. i'll do that on sat
  25. Junior Member
    May 12th, 2012
    Concord, NC
    07 GTI
    09-20-2012 05:44 PM #25
    The bottom of the smc trap is where I had my leak. my first trap was fine until I drained it the first time, then it wouldn't seal up. Would leak about 15-20 PSI overnight. Same thing happened with the new SMC that I bought. So I just switched to the parker high pressure traps this morning waiting for the loctite to cure overnight. Hopefully its good to go tomorrow.
  26. Member Slamtastic's Avatar
    Jul 24th, 2010
    Calgary, Alberta
    09-20-2012 10:44 PM #26
    You shouldn't have any leaks. It's lazy and unsafe.
  27. Member
    Mar 28th, 2007
    iowa
    07 uni black rabbit
    09-20-2012 11:12 PM #27
    i admittedly don't have any long-term anecdotal experience with air setups (just finished my own), but being an engineer this is precisely where i'd expect a seal failure to result if DOT fittings were used the rest of the way through. NTP fittings are easy to manage (i.e. coat liberally w/ thread sealant and wrench the **** out of without much fear of breaking), trap closures not so much.
  28. Member dubb34r's Avatar
    Apr 3rd, 2011
    ATL
    10-15-2012 09:29 PM #28
    Forgot to post an update, here it is.
    All leaks are gone. Tank was fitted with all new fittings and loctite 545. Also got rid of the elbow PTC going into the manifold as they where leaking no matter how I placed them.
