Results 1 to 4 of 4
Thread: trouble with my engine! need help
  1. 07-15-2012 05:20 PM #1
    Hi, I had some trouble with my engine at the begining of this summer, it was running like crap at 3k rpm at 5k rpm.
    So I read the tread on that problem in this tread and did a big tune up on my corrado.
    I changed: fuel pump, all vaccum line, spark plugs, rotor and distributor, blue and black sensor in coolant, boost hose clamp, clean all injectors, injectors seals, clean up throttle body and intake.
    I repared a lot of electric wires too in the engine bay that was very bad!
    After all, I tried to start my engine, but it would'nt start.
    Fire was ok, but when I looked for fuel I had fuel at my fuel rail, but I did'nt have fuel at the return of the FPR, is that supposed to be ok?
    It' s looked like I had fire, but I'm not sure that my fuel injection work!
    I check my timing to be sure that it was ok and I think it's good!
    I'm not a mechanic, but I dont know what I have to check and In the benmtley they always talk about tha VAG ....
    I mesure in ohms my injectors to be sure that they were ok and had 4 ohms.
    Let me know what I have to tried to get this beast on the road again!
    Thanks!
    Phil
  2. Member petethepug's Avatar
    May 25th, 2001
    So Cal
    Orig Owner 90 G60 & 02 Allroad 6Sp Man w/ 3rd Row Seat
    07-15-2012 07:20 PM #2
    Check this out and scroll down to the 2nd half of the page
    http://www.corrado-club.ca/forum/viewtopic.php?t=10293
    ¡¡ opɐɹɹoɔ ǝɥʇ!!!ƃuıʇɔǝdsǝɹ !!!
    !! odarroɔ ǝht gnitɔepser !!
  3. 07-21-2012 01:22 PM #3
    I read those tread, but still dont know how to check the FPR!
    I just want to know if it's supposed to have fuel in the return line to the tank when I tried to start the engine, it will help me.
    I will tried to find a fuel pressure gauge to know how much fuel pressure I have at the FPR.
    Thanks!
    Phil
  4. Member petethepug's Avatar
    May 25th, 2001
    So Cal
    07-21-2012 03:23 PM #4
    Hey Phil the FPR is not a likely cause of it running poorly like you describe. Grab a beer and read a bit more.
    What you've done and what's still going on can be a couple of things.
    • You mentioned new Dist and rotor. Doesn't new dist come w/ the rotor. I'm trying to rule out a bad Hall sensor in the old Dist. A replaced Dist would mean you have a new Hall sensor.
    • Worn intermediate shaft allowing distr to get sloppy.
    • Vacuum line to ecu has a rub out (leak).
