Results 1 to 2 of 2
Thread: SLC Noise
  1. Junior Member
    Aug 30th, 2011
    Virginia Beach
    90 G60
    07-15-2012 05:30 PM #1
    I'm looking at a 93 SLC while on deployment the owner says "There is some clicking in the engine in low gears, which at times can cause the car to stall; it sounds like a small switch or valve that is flipping intermittently; I haven't had time to investigate this further so I cannot provide additional details"Has anyone come across this problem before? I'm a old G60 guy so not realy used to VR6 problems
  2. Member krager54's Avatar
    Aug 6th, 2011
    Aloha/Beaveton, Oregon
    1984 VW Jetta 1.7 gas
    07-15-2012 05:46 PM #2
    Quote Originally Posted by classicinjection View Post
    Ask him when the last time the timing chains were done? Does the sound go away at higher rpms? It could be the chain slapping against the guide before it goes tight.
    That's only if the sound is actually coming from the motor.
    Quote Originally Posted by DUBZAK View Post
    Welcome to Corrado ownership 101. Cheap out or hold off on important items, it will cost you 3 fold vs doing it right one time.
