Results 1 to 7 of 7
Thread: QUESTION shaving secondary air
  1. Member mattrepka's Avatar
    Sep 6th, 2009
    south brunswick, nj
    05 golf 2.slow
    07-16-2012 09:11 AM #1
    my buddy has done his 1.8t and another friend his r, using a block off plate behind the motor at the beginning of the secondary air hose, my question is i cant seem to find a block off plate for the 2.0 motor, has anyone done this? what have they done? another friend said he plugged his with some sort of bolt but it didnt work well...also caused his fans to constantly run, any info would be great
  2. Member mattrepka's Avatar
    Sep 6th, 2009
    south brunswick, nj
    05 golf 2.slow
    07-19-2012 03:10 PM #2
    bump
    Mar 6th, 2002
    Morris Plains/Parsippany, NJ
    1998 GTI 2.0
    07-23-2012 09:05 AM #3
    What are you trying to gain? The only thing you'll gain from deleting SAI is a blazing CEL on the dash. Oh, and let's not forget the legal issues you'll encounter in NJ.
    There is no power, economy, or any other gain to be had from removing it. If it's not working, it's easier to fix it than remove it anyway, very simple system.
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  4. Member mattrepka's Avatar
    Sep 6th, 2009
    south brunswick, nj
    05 golf 2.slow
    08-01-2012 04:50 PM #4
    im shaving the bay
  5. Member mattrepka's Avatar
    Sep 6th, 2009
    south brunswick, nj
    05 golf 2.slow
    08-01-2012 04:51 PM #5
    so back to the original question
  6. Member Dub'dRite's Avatar
    Jul 16th, 2007
    Central Fl
    RIP 02 VR6 Jetta, 05 Lagoon Blue GLI, 99.5 2.0 "Super White" Jetta Shaved Bay...Votex Kit'eddd
    08-02-2012 12:26 PM #6
    Quote Originally Posted by mattrepka View Post
    If its AEG its gonna be on your exhaust manifold...you will see a small port on the driver side just under where the "combi" valve is located coming down from your tb...you can use a bolt with some jb weld..or just weld it closed..I just did it ony my AEG shave. turned out pretty nice I'd say
  7. Member mattrepka's Avatar
    Sep 6th, 2009
    south brunswick, nj
    05 golf 2.slow
    08-29-2012 06:36 PM #7
    Quote Originally Posted by Dub'dRite View Post
    thank you for the info, helped alot, so i guess its safe to say no company makes a block off plate lol
