Results 1 to 6 of 6
Thread: Keeping batteries charged
  1. 07-16-2012 11:47 AM #1
    2008 vr6 eos
    Having some issues with batteries no 100% after a week or 2 in the garage... Looking for a way to hook it up to a trickle charger for those extended garage stays... I don't want to hook it up in the engine compartment, and can I hook directly to the batteries?
    Nov 27th, 2009
    50 Miles South of Tucson AZ
    2013 CC and 2009 Eos
    07-17-2012 02:40 AM #2
    Quote Originally Posted by sr3051 View Post
    2008 vr6 eos
    Since your batteries are hooked up in parallel, there is no reason why you cannot attach a 12 volt trickle charger to any one of the 6 volt units.
    By the way, the trickle charger will increase the life of your batteries by many times fold.
    2013 CC Sport Plus, K@N Air Filter, LED Interior Lighting Including Foot Wells, 18" Interlagos Wheels w/ Cooper tires.
    2009 Eos, Tech Package, RNS510, K&N Air Filter, Silver/Black Leather Seats, Sherwood Aluminum Dash Kit, LED Interior Lighting, Underbody LED Safety Lighting, Under Seat Drawer.
  3. 07-17-2012 03:52 PM #3
    I am confused as to why the 2, 6v batteries would be in parallel in a car with a 12 v system. Anyway you could probably connect the charger at the batteries. But why not just use the battery jump connections under the hood. It would be simpler. As long as the charger is connected, the hood or trunk would need to be open.
  4. Member
    Nov 27th, 2009
    07-17-2012 04:08 PM #4
    Quote Originally Posted by cb391 View Post
    I wasn't thinking before typing, last night. I should have said, they are connected in SERIES. Duhhhhhhh.
    And, you are right, he can just use the jumper points under the hood. Afterall, that's what they are for.
    Jul 26th, 2011
    2004 TTQ 225 2008 VW EOS 3.2
    07-17-2012 09:16 PM #5
    Good Stuff!!
    2004 TTQ 225 Blueflame Exhaust, APR, Modshack, Dieselgeek Shortshift
    2008 VW EOS 3.2 DSG
    2009 Volvo XC90 V8 R-Design AWD
    Never underestimate the power of stupid people in large groups.
  6. 07-17-2012 10:50 PM #6
    The trickle chargers i have seen have a break away cable which lets you leave the clamps on the battery and just break the wire when you want to disconnect. if i leave this under the hood it would most likely get messed up, this is why i was looking for a way to hook it up to the batteries (in the trunk) with the wire coming out and leaving the charging device on the ground behind the car.
