Results 1 to 10 of 10
Thread: Alternatives to V-Band, Wiggins, etc.
    Feb 10th, 2002
    Pittsburgh, PA
    '94 Jetta, '08 Rabbit, '12 2500HD
    07-16-2012 11:51 AM #1
    I'm looking for an alternative to V-band, Hargett, or Adel Wiggins connectors. I want something that looks slim and smooth, those three are too bulky for me. It doesn't need to be flexible, but that would make fabrication a bit easier. I only need one (throttle body, no boost) so cost isn't a big deal.
  2. Member polov8's Avatar
    Apr 14th, 2004
    United kingdom of Awesomecestershire
    '80 Scirocco Storm, '79 Scirocco, '01 BMW E39 530D
    07-16-2012 01:07 PM #2
    I doubt you'll find anything more compact to do what you want than a wiggins clamp.
  3. Member Bazmcc's Avatar
    Jan 10th, 2005
    Northern Ireland
    2002 Bora TDI, 1994 2.0 16v Corrado, 1991 MK2 Golf, 1983 MK1 Golf Driver, MK4 Golf, 1971 Fastback
    07-17-2012 07:11 AM #3
    Quote Originally Posted by polov8 View Post
    x2
    The wiggins clamps are easily the smallest pipe clamps. You're only other alternative is to go with a TIG welded hardpiped solution.
  4. Member
    Feb 10th, 2002
    Pittsburgh, PA
    07-17-2012 07:34 AM #4
    Thanks, Maybe I'll just go with Wiggins. I like the Accufab clamps too, I have never seen one in person though.
  5. 08-25-2012 12:34 AM #6
    just saw this, thanks Chad.
    this setup is handling 43+ psi and low 9 sec 1/4 mile passes easily.
    and after getting and using, i wouldnt have it any other way. they work and are simple to use.
  6. 09-03-2012 10:41 PM #8
    Quote Originally Posted by California Jay View Post
    I may be biased,
    http://vibrantperformance.com/catalo...1022_1250_1306
    We have just finished testing in the diesel market for 130 psi.
    Any plans for 2.75"?
    Feb 10th, 2002
    Pittsburgh, PA
    09-03-2012 11:04 PM #9
    2.75 is what I need too; those look pretty good!
  8. Member 1SlowSLC's Avatar
    May 4th, 2003
    boxes of parts
    09-20-2012 12:14 AM #10
    I'm really diggin those vibrant clamps..
    FS: Fikse FM-10 17x8 17x9 Fully refurbished, custom kodiak lips, BFG KDW2 rubber 205-40-17, 215-40-17 / FS: Mk2 GTI Vr6T- needs head gasket and cooling system once over, and retune
    FIND BOTH HERE: http://forums.vwvortex.com/showthrea...turbo-(S.-FLA)
