Results 1 to 31 of 31
Thread: FS: Perforated leather/brushed aluminum shift knob and boot
  1. 07-16-2012 03:13 PM #1
    This is a brand new (never used or installed) 5-speed OEM shift knob and boot, which fits directly into MK4 Golf/Jetta.
    - The shift knob is a genuine OEM Audi S-Line knob covered in perforated leather with brushed aluminum ring. It includes an OEM clamp to secure it to your shifter. The shift pattern is 5-speed.
    - Shift boot is made from perforated genuine leather, double-stitched with grey stitching (I can probably get red, white or other stitching)
    - Also included is a brand new VW OEM plastic shifter surround trim ring, so it's truly plug and play.
    This is an excellent replacement for your stock shift knob/boot combo. The shift knob is slightly thicker, more substantial, and feels much better than the original shift knob in your VW. I have one in my car and love it.
    The price is $125 firm including shipping within Canada.
    Or $115 shipped without the plastic shifter retainer trim if you'd like to re-use yours.
  2. 07-19-2012 11:03 AM #2
    Bump
  3. 07-21-2012 05:52 PM #3
  4. Member BSMSG's Avatar
    May 12th, 2003
    Sarnia Ontario
    2001 Jetta GLS 1.8T
    07-21-2012 07:42 PM #4
    i like so i'll Bump.
  5. Member DHB's Avatar
    Aug 12th, 2010
    Toronto
    2001 wolfsburg 1.8T jetta 2002 Jetta 2.SLOW (R.I.P.)
    07-22-2012 01:59 PM #5
    U in the Toronto area ???
  6. 07-23-2012 07:10 AM #6
    Quote Originally Posted by BSMSG View Post
    Thank you! Cheers
  7. 07-23-2012 07:10 AM #7
    Quote Originally Posted by DHB View Post
    In NS.
  8. 07-23-2012 04:27 PM #8
    Would this fit a MK3?
  9. Member BSMSG's Avatar
    May 12th, 2003
    Sarnia Ontario
    2001 Jetta GLS 1.8T
    07-23-2012 06:23 PM #9
    i had one in my mk3 . just had to screw it on . not sure about the bottom part of the boot... mine had elastic
  10. 07-23-2012 08:32 PM #10
    Quote Originally Posted by c5ho View Post
    As previous poster mentioned, it should screw on, but I haven't tried it. The diameter of the shifter rod should be comparable (12mm?).
    The boot has elastic sewn into it, so you can just buy it without the trim ring and stretch the boot over your existing trim ring. They look similar in size from this DIY: http://forums.vwvortex.com/showthrea...II-Golf-Jetta*
    No need to cut into your trim like in the link above as they used a different MKIV shift boot base then the one I'm showing above.
    Hope this helps and hope you'll give it a try!
  11. 07-26-2012 09:44 PM #13
    thats a nice shifter.
  12. 07-28-2012 07:42 AM #14
    Thank you! Yes, it looks very nice in a car and feels much better than stock.
  13. 07-31-2012 04:04 PM #15
    Bump
  14. 08-04-2012 08:25 PM #18
    Happy weekend!
  15. 08-06-2012 09:49 AM #19
    Happy holiday!
  16. 08-08-2012 10:01 PM #20
    Bump
  17. 08-14-2012 12:40 PM #22
    Still available.
  18. 08-15-2012 10:12 AM #23
    To the top
  19. 08-20-2012 01:40 PM #24
    One available without the bottom trim for $115 shipped.
  20. 09-11-2012 07:04 AM #25
    Back from vacation bump
  21. Member justinash54's Avatar
    Jun 13th, 2009
    ephrata pa
    2002 jetta wagon glx, 02 b6 a4
    09-14-2012 04:45 PM #28
    The one you have available without the trim ring. Is it grey stitched?
    Sent from my DROID RAZR using Tapatalk 2
  22. 09-14-2012 11:33 PM #29
    Quote Originally Posted by justinash54 View Post
    Yes, it has grey stitching. See the pictures above.
    Please send me a PM if you are interested.
    Thank you.
  23. 09-16-2012 11:16 AM #30
    Still available
  24. 09-17-2012 07:59 AM #31
    Happy Monday
