Results 1 to 4 of 4
Thread: Soldering help
  1. Member KeiCar's Avatar
    Jul 22nd, 2002
    Philly (past & present) -- Bangkok, HK, Singapore (future).
    2000 Honda CRV SE / 2012 Samsung Galaxy S3
    07-16-2012 05:49 PM #1
    I just busted the power switch off the motherboard of my Acer tablet
    I have the unit dissembled and I tried my best to clean off the solder pads where the switch goes. Its a SMD design which Ive never done before. I would rather pay someone local to fix this, but if I cant find anyone Ill try it myself (gotta learn eventually).
    Would a heatgun generate enough heat to melt the solder (im sure it will)? My problem though is that the switch has plastic components to it that might melt. Since this is a smd part, I cant get to the solder points, which are very small, with the iron to do it that way...
    Any advice?
    Few people understand the psychology of dealing with a highway traffic cop. A normal speeder will panic and immediately pull over to the side. This is wrong. It arouses contempt in the cop heart. Make the bastard chase you. He will follow.
    Dec 31st, 2005
    SoCal
    Corvette & SV650
    07-16-2012 08:28 PM #2
    You can melt solder with an soldering iron. Using heat gun... Ouch. That's like washing your hair with a pressure washer. I'm not sure about wicking the old solder though. Lots of kits have stuff to wick the old solder, I just haven't done it before. I also haven't soldered anything finer than 10ga wire. Good luck.
    Try finding a community college engineering student? I bet one of them is decent with a soldering iron and won't charge much.
    Quote Originally Posted by apizzaparty View Post
    never thought once to use my lefty for the brake. sorry in my opinion it is dumb.
  3. Member KeiCar's Avatar
    Jul 22nd, 2002
    07-17-2012 12:07 AM #3
    No you dont understand, getting to the solder points is difficult since there are other components in the way. The part blocking access is the vibrator motor, which is large (relatively speaking) and I would not be able to get the tip of my solder gun in there. Perhaps if I can get a smaller tip, but it would need to be VERY small, like the tip of a sharp pencil, small and a narrow shaft as well (don't laugh)....
    Ahhh. this sucks.
  4. Member
    Dec 31st, 2005
    SoCal
    Corvette & SV650
    07-17-2012 12:24 AM #4
    Can you access that point from the other side? Perhaps heat up the point from the back? Trying to get the timing of having everything stay hot enough before you install the part is going to be tough though.
    You could file down the tip of your soldering iron. Lots of people, myself included, do that to make inexpensive hot knives. You'll need a different shape tip, but it's the same principle.
