Results 1 to 5 of 5
Thread: New A6 Base Project
  1. 07-17-2012 02:31 PM #1
    Okay so i just bought an Audi A6 Quattro 2.8l and it has some issues.
    it has 87k on it and its a 99. its been taken care of timing belt was done at 80k oil changed every 3k and paperwork to prove it.
    PO was dirving it and all of a sudden it started sputtering and bucking, he was 10 miles from home so he just drove it and parked it and then i bought.
    the car starts and rev's to about 2k rpm and then bogs down.
    EDIT: so i took my spark plugs out to test compression and this is what i found... they were covered in oil? it was on the wrench too so i think its a valve cover gasket leak. its on both cylinders 1 and 4 i havent checked any others. what do you guys think? could it be valve seals?
    here is the most recent scan
    Address 01: Engine Labels: 078-907-551-AHA.lbl
    Control Module Part Number: 4D0 907 551 AH
    Component and/or Version: 2.8L V6/5V MOTR AT D04
    Software Coding: 06252
    Work Shop Code: WSC 02325
    VCID: 6CD3C083361B
    3 Faults Found:
    17953 - Throttle Valve Controller: Malfunction
    P1545 - 35-00 - -
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-00 - -
    16688 - Cylinder 4: Misfire Detected
    P0304 - 35-00 - -
    Readiness: 0110 1101
    so i think i need a coil pack and maybe a throttle body?
    i dont know about the throttle body though i thought i would just need to do a TBA but when i went to do it, it said error. maybe thats cuz of the misfire.
    anyone's input would be great. thanks.
    oh and pics
    Quote Originally Posted by SoIAteAPancakeToday View Post
    it would whisper in your ear, "lrn2offsetbrah."
    Oct 6th, 2004
    Mill Creek, Washington
    '99 Civic Hatch, '04 Audi A6
    07-17-2012 05:22 PM #2
    Coil packs? I had a similar problem a while back and it was a bad coil pack.
  3. 07-17-2012 08:39 PM #3
    i just purchased a used coil pack from the classifieds and a new valve cover gasket from ECS.
    i will keep this updated and let you know if it fixes the problem.
    i bought this car for 900$ i should make out pretty good on this one.
  4. Member dieselgeek's Avatar
    Jun 23rd, 2004
    Dirty Jersey
    00/Audi/A6 2.7T , 92/VW/Cabby , 87/VW/GTI
    07-18-2012 07:29 AM #4
    $900!!!!! Wow! You stole that car.
  5. 07-18-2012 12:01 PM #5
    Quote Originally Posted by dieselgeek View Post
    i know i'm pretty pumped about it. part of me wants to keep it cuz it is sooo clean with no rust and only 87k on it. but i am broke and need the money right now.
    but i am hoping i can get like 5k$ for it in such good condition with such low miles.
