Page 1 of 2 1 2 LastLast
Results 1 to 35 of 65
Thread: 1979 Rabbit VR6 coupe.
  1. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    07-17-2012 08:39 PM #1
    SOLD
    Ive owned this car since 2002. I bought it in California and drove it home to Tennessee.
    1979, German built car. California car
    Alpine white, original paint. Zero rust on this car anywhere.
    Interior is 9.5 out of 10. Very very clean in there. Everything works perfectly in the interior including tach, speedo, heater, all lights, signals, etc. Blaupunkt radio works but is currently not hooked up. There is an OEM speaker in the dash that does work.
    I did this swap right and feel confident in saying I didnt cut corners or spare expense....as seen by the new parts list you'll find below. Everything has been done logically and with an attempt at an OEM looking install. You can ask me anything you want about it.
    I will attempt to list all the parts on this car...
    Engine/Tranny: 2.8 VR6. The following parts are new with maybe 3k miles on them..... Battery, K&N filter ,fuel pump, fuel filter, gas tank, plugs, wires, flywheel, clutch, water pump, all hoses, crack pipe, corrado VR radiator, coolant jug, dual 10" fans, low temp thermostat, low temp fan switch, all seals and gaskets, o2 sensor, coolant sensors, axles, serp pulley bearing, serp belt, BFI poly mount on tranny, VF mount on passenger side, VW mounts elsewhere, 2.25 Eurosport exhaust, wheel bearings, Claus von Essen rod linkage kit from Germany (shifts amazingly), mk4 hydraulic clutch set up (clutch slave, master and hose are all new).
    BTW, this ECU may have a chip but not sure. Runs like it does to me with no speed limiter. It does have a redline limiter. The car runs perfectly with never a problem. Always ran synthetic oil, OEM pink coolant and 92 octane gas.
    Secondary air delete, EGR delete, Cat delete. Downpipe and exhaust tip are aluminum-ceramic coated.
    Suspension: KW coilovers, old school Autotech upper front stress bar, Eibach lower front stress bar, Neuspeed rear sway bar. Poly a-arm bushings.
    Brakes: 10.1" Brembo with drilled rotors up front braided lines, 9.4" rear disc... Brembo drilled rotors, New 22mm master cylinder.
    Exterior: 15" ATS cup 15x7 et28, Toyo 195/45 T1Rs with very little wear at all. Chrome small metal eurobumpers. Perfect condition, Hella clear turn signal lenses. New grille and front badge.
    Interior: All OEM stock except for new CoCo floor mats.
    Windshield has gotten a rock hit on it (can be seen in the center of the glass in the front pic. Paint is OEM so has its bug chips here and there, a few scratches. Right rear quarter just near the taillight has been repaired at one point. The job wasnt perfect but in my years of owning the car it has yet to change and has no rust. You may can see this in pics I think but I am happy to take detail shots. Under the windshield there is a small odd place that may can be seen in pics. Has no rust there but may have been repaired at one point too. I may have forgotten some parts so may add as time passes.
    I can take any pics you want of details, etc. Just ask.
    $8350 cash
  2. Member Conejo Negro's Avatar
    Apr 2nd, 2007
    Yonkers Ny
    1976 Volkswagen Rabbit
    07-17-2012 09:34 PM #2
    Bump for a very pretty car
  3. Member Ungarisch's Avatar
    Jan 14th, 2002
    Hollywood, CA
    2001 MB W210 Wagon
    07-17-2012 11:27 PM #3
    God damn, if I could register (legally) this in California again, this car would be on the transport truck by now.
  4. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    07-17-2012 11:39 PM #4
    Quote Originally Posted by Ungarisch View Post
    It has a diesel title.
  5. Member Ungarisch's Avatar
    Jan 14th, 2002
    Hollywood, CA
    2001 MB W210 Wagon
    07-17-2012 11:40 PM #5
    still need to go thru odometer reading inspection when importing car registered out of state
    EDIT: however, last time, when I imported my current benz from texas, they never asked me to open the hood. Just checked the odometer and VIN as well as door jam sticker.
    Maybe I can hide a boombox under the hood and loop a tape of diesel sound, ahahahaha
  6. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    07-18-2012 09:22 AM #6
    Nov 8th, 2002
    Whitefish, MT
    2004 Forester 1997 LX450 1975 Rabbit
    07-18-2012 11:00 AM #7
    April Fools?
  8. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    07-18-2012 11:20 AM #8
    Quote Originally Posted by PoorHouse View Post
    April Fools?
    Nope.
    Nov 8th, 2002
    Whitefish, MT
    07-18-2012 11:41 AM #9
    Hmm, would be on this in a second if I hadn't just bought the '75.
    Well, good luck with the sale, someone is getting a very good deal.
    Look forward to seeing what the next project is, VW or not.
  10. Member
    Feb 7th, 2012
    Lancaster, PA
    07-18-2012 02:16 PM #10
    Where in Tennessee are you? What kind of miles does the vr6 have on it?
  11. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    07-18-2012 02:23 PM #11
    Quote Originally Posted by planksta View Post
    Im in Nashville.
    I dont recall 100% on the mileage. Someone came to look at the car last night and I was trying to remember. I told him about 75k but I think its just slightly more iirc.
    Runs strong for sure. The car is brutal, really.
    Feb 7th, 2012
    Lancaster, PA
    07-18-2012 03:09 PM #12
    Quote Originally Posted by deathhare. View Post
    Im in Nashville.
    Nice thats nothing for a vr6 and seems well maintained, looks bad ass, im 12 hours away and thats not phasing me one bit, wonder how much it would be to ship it
  13. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    07-18-2012 03:38 PM #13
    I shipped a Caddy to Michigan a year or so ago.
    I dont remember exactly but it seems like it was about 800-900.
    I may be way off on that. Someone else here would know better than me Im sure.
  14. Member christian23's Avatar
    Apr 25th, 2009
    philly
    corrados,gti's,jettas,m3's,rx7
    07-18-2012 05:06 PM #14
    niceglws
  15. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    2008 CW R32, 1983 CW Rabbit LS
    07-18-2012 05:11 PM #15
    So rad.
    Holy Milltek.
    Tarmacs cut it close.
    Miami Vase
    Cams A Make Her Dance
  16. Member kslater's Avatar
    Oct 8th, 2009
    western ma
    04 gti
    07-18-2012 08:05 PM #16
    considering any trades? i have a bagged mk4 lemme kno
  17. 07-18-2012 08:43 PM #17
    PM sent.
  18. Member
    Aug 2nd, 2010
    Central Pennsylvania
    '73 beetle, '81 pickup, '13 GTI
    07-18-2012 09:02 PM #18
    Awesome.
  19. Senior Member IronTrap's Avatar
    Jun 14th, 2001
    Gilbertsville, PA
    '50 Dodge Pilot-House, '52 DKW 125W, '76 Rabbit Ocean Bleu X2,EA Cabriolet,'77 Scirocco
    07-18-2012 09:14 PM #19
    One of the most tastefully modified OEM+ Mk1's on the vortex and a great price. GLWS Shan, what's next?
  20. Junior Member rossonero's Avatar
    Apr 17th, 2012
    DC
    '99 Beetle, '04 Passat V6, '11 Golf GTI, '91 Jetta GL
    07-18-2012 11:43 PM #20
    issaaaniiiice!!
  21. Member Pants!'s Avatar
    Nov 25th, 2011
    1983 GTI 1.8 8v
    07-19-2012 12:06 AM #21
    /bump for being a sleeper.
  22. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    07-19-2012 01:03 AM #22
    Quote Originally Posted by kslater View Post
    Not into trades at all.
    Thanks for all the comments and bumps.
  23. 07-19-2012 03:25 AM #23
    Baddest car on this ****ing website hands down. Done right so damn sexy
  24. Member jpawl's Avatar
    Apr 12th, 2000
    Lynn, MA
    2008 Gti, 1984 Rabbit Gti Callaway Stage II, 1983 Callaway Stage I, 1995 Nissan King Cab
    07-19-2012 08:09 AM #24
    Looks very nice.
    Jim
    Jim
    2008 Gti, 1984 Rabbit Gti Callaway Stage II, 1983 Rabbit Gti Callaway Stage I
    My VW's past & present
  25. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    07-19-2012 04:23 PM #25
    As requested by many, a few detail shots.
    Not sure if I mentioned but the car is original paint.
    If you have questions about specific pictures, I can explain.
  26. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    07-19-2012 08:19 PM #26
  27. Member 02RedGTIVR6's Avatar
    Oct 3rd, 2011
    B-More
    DEAD 02 gti vr6, 95 GTI VR6, 89 GTI 16v classy rat rod, 81 diesel rabbit daily
    07-19-2012 08:59 PM #27
    now thats serious power to weight ratio
    weight distribution not so good but who cares when your hauling ass
  28. Member Conejo Negro's Avatar
    Apr 2nd, 2007
    Yonkers Ny
    07-20-2012 06:16 AM #28
    Its only like a 150 lbs more the power is worth it!
  29. 07-20-2012 07:24 AM #29
    Looks great and nice mods... BTW, its had paint work in several areas from your pics - doesn't detract from it - just sayin'. Might have had a light bump in the back as the hatch and below is repainted, and the cowl looks like might have had some attention once before too.
  30. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    07-20-2012 09:49 AM #30
    Quote Originally Posted by spinnetti View Post
    It had that bump and been fixed like I said but the hatch and below are definitely original paint.
    Ive had the car for 10 years. If the rear was painted it was done very professionally.
  31. Member MK2*GTI*GUY's Avatar
    Sep 2nd, 2001
    Fullerton, CA
    2010 R1 LE Fiat Edition -- 98 M3 Sedan -- 04 Evo 8 RS -- 96 Golf Harlequin
    07-20-2012 10:04 AM #31
    Saw it on Bringatrailer.com this morning too.
    VR46 ----"THE DOCTOR"
  32. 07-20-2012 10:17 AM #32
    Beautiful car. Nice work. I'd love to own it myself.
  33. Member davela72's Avatar
    Jun 7th, 2000
    PA
    1990 Cabriolet, 2012 GTi
    07-20-2012 10:22 AM #33
    Damn Shannon, very nice! Its nice to see something that's put together the correct way.
  34. Member Gustaf's Avatar
    Sep 16th, 2000
    Gilbert AZ
    Euro E24, A3 3.2 Quattro S-Line
    07-20-2012 01:56 PM #34
    I dig GLWS
    Quote Originally Posted by DG7Projects View Post
    It's like an R32 in a suit.
    EDIT:
    It IS an R32 in a suit.
  35. Member MickR's Avatar
    Jan 27th, 2011
    Baltimore, Meowyland
    1977 Scirocco, Protege 5, Mobylette
    07-20-2012 02:42 PM #35
    Incredible. GLWS
