Turbo is fine, sounds like you have a HPFP issue, which may cause misfires if the problem causes too lean or rich a fuel mixture.
#1
5 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 154631 km
Time Indication: 0
Date: 2000.00.00
Time: 11:21:59
Freeze Frame:
RPM: 3509 /min
Load: 58.8 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 40.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.589 V
000772 - Cylinder 4
P0304 - 000 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 154631 km
Time Indication: 0
Date: 2000.00.00
Time: 11:22:01
Freeze Frame:
RPM: 3637 /min
Load: 59.6 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 39.0°C
Voltage: 13.589 V
000135 - Fuel Rail/System Pressure
P0087 - 000 - Too Low - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 154631 km
Time Indication: 0
Date: 2000.00.00
Time: 11:22:11
Freeze Frame:
RPM: 1297 /min
Load: 63.5 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 40.0°C
Voltage: 13.843 V
004874 - Cylinder Disabling
P130A - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 3
Mileage: 154631 km
Time Indication: 0
Date: 2000.00.00
Time: 11:25:01
Freeze Frame:
RPM: 772 /min
Load: 41.6 %
Speed: 0.0 km/h
Temperature: 55.0°C
Temperature: 42.0°C
Voltage: 13.970 V
000769 - Cylinder 1
P0301 - 000 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 154633 km
Time Indication: 0
Date: 2000.00.00
Time: 11:27:58
Freeze Frame:
RPM: 1946 /min
Load: 44.3 %
Speed: 68.0 km/h
Temperature: 71.0°C
Temperature: 39.0°C
Voltage: 13.716 V
Readiness: 0110 1101
What can be the problem?
I've searched on vortex and I noticed plenty of people mention under this topic that it may be the turbo charger is going bad. I just need more thoughts to hopefully come to a conclusion that this is the problem and nothing else.
Thanks Guys.
This is the video of it posted below..
http://youtu.be/lRGIdnE0Ll4
#2
#3
looks like your injectors are sticking open causing no fuel pressure and a ton of unburned fuel in going into the exhaust.
2012 Jetta Tdi
H&R sport springs
15% tint
VW Technician
VAGCOM equipped, willing to help with it if in pacific NW area. Hit me up.
#4
#5
Doesn´t look like "white smoke", but unburned fuel (vapour)......
Your turbo seems to be just fine.....otherwise you would see lots of smoke......
#6
#8
You are correct.
My 4th injector is stuck open.
2 of my cylinder seals are bad, and the compression of each cylinder from 1-4 is 118, 118, 110, 105.
Need piston rings.
That should do it.
#9
I am glad you did not have issues with ECU or gateway module. Good luck. Makes me wonder how much my issue was really caused by the tune.
