Originally Posted by
WaterWheels
First - No. That short answer said, you will understand or see more information below.
Second - The part which moves the contact over the resistor board is just what you called it, a "float". So it is normal, natural if you like, for it to be effected by vehicle motion or angle. Diferent makes and different models will react in different ways. The same goes for like make and models that have had repairs done and things not installed in the exact correct position. i.e. If someone replaced the transferpump and installed the unit say 5° off, it will react different from one set from the factory.
The regulator, if you mean voltage regulator, should have no effect. The voltage the gauge uses is maintained at a constant 10v for the reason you stated. But fuel gauges can and do read odd for the most part due to many things. Wear in the resistor board, old and failing gauge, bad contacts in the wiring, floats which have become bad or wear of the assembly itself are some reasons. I have always found the gauges to read slower for the firts quarter, then about normal in the middle and faster in the last quarter. Even with the odometer not working, you should be able to get a good fuel consumption figure using the speedometer. If your tire sizes are not standard this will throw the reading off also.
