Results 1 to 8 of 8
Thread: drivers side bi xenon stopped working
  1. 07-18-2012 09:01 PM #1
    hey all seems like im having a lot of issues with the gli lately. i replaced two fans this week and when i took the car out of the garage it appears on the test drive my drivers side bi xenon stopped working
    no light. im fairly new with this car but the dealer told me it could possibly come back ? i dunno and this is a d2s bulb on 2006 jetta gli right? its rotting me the last to nights, so any have any advice ?
  2. Member xJOKERx's Avatar
    Apr 8th, 2009
    Dallas, TX
    07-19-2012 12:05 PM #2
    Quote Originally Posted by cochise View Post
    is it not turning on at all? or is it a different color (pinkish color)? HID Bulbs don't burn out they change color as the bulb salts are burned out in the bulb. If it's not turning on it's probably the ballast that needs to be changed.
  3. 07-20-2012 06:17 PM #3
    yeah not turning on at all , just gone no discoloration or anything, hmm ballast sounds expensive , how could i check that?
  4. Member xJOKERx's Avatar
    Apr 8th, 2009
    Dallas, TX
    07-22-2012 02:02 AM #4
    if OEM they can bet - definitely look up a part number do some searching around
  5. Member RonJon749's Avatar
    Apr 23rd, 2008
    Connecticut
    2009 GTI
    07-23-2012 08:31 PM #5
    I am having a similar problem with my passenger side HID on my 2009 GTI, except, when I remove the ballast and the bulb from the housing, keep it plugged in and turn the headlight on....the bulb flickers and then turns off. When I turn the lights off then back on again, same deal. Bulb flickers then turns off. Now, I did notice earlier that the bulb got much less intense and became purple-y in color.
    Bad Bulb?
    Lowered 2009 Platinum Grey VW GTI. 6-Speed. A Few Mods. Wheels Pending.
  6. 08-02-2012 07:40 PM #6
    does anyone have a part number for this HID ballast on a 2006 jetta gli? just wanna know what i should be bidding on ebay.
  7. Member RonJon749's Avatar
    Apr 23rd, 2008
    Connecticut
    2009 GTI
    08-05-2012 07:29 AM #7
    If you haven't remedied this problem yet, try switching the bulb and ballast with the other headlight, that way if the bulb still doesn't come on, you know Its the bulb. If the bulb illuminates it's the ballast that is the problem.
    In my situation, I found out it was the bulb. I bought a new set of 4,000K Phillips Germany D2S CrystalVision Xenon HID's. I found them on Amazon for $143. Problem solved.
    I didn't grab the part number of the ballast, but it (should) be labeled on it, somewhere.
    But, The dealer wanted $160/Bulb and $190-ish for each ballast.
    Hope all works out!
  8. Member rickjaguar's Avatar
    Apr 23rd, 2009
    Van. Island, BC
    07 GTi.. fun times
    08-13-2012 02:35 PM #8
    slightly off topic here but before i attempt replacing my xenon bulbs (07 GTI) i'm just wondering if there's a DIY somewhere or if it's pretty straightforward?
    (i know to not handle the bulb directly)
    Sent from my 1st generation Motorola brick using Tapatalk
