Results 1 to 2 of 2
Thread: Tooth count of main drive gear. What difference does it make?
  1. Member KeiCar's Avatar
    Jul 22nd, 2002
    Philly (past & present) -- Bangkok, HK, Singapore (future).
    2000 Honda CRV SE / 2012 Samsung Galaxy S3
    07-19-2012 02:55 AM #1
    Im shopping for a replacement main gear because mine is starting to show wear. Actually let me back track for a sec, Im not sure if its really called the "main gear" but here is the setup: (Its a RC18t BTW, 4WD with shaft driven front & rear diffs). Its the shaft gear Im talking about. First you have the motor and it has a small gear on it, which in turn drives a larger gear, which is attached to the main driveshaft. That larger gear is the one I am replacing.
    I think stock is 56 or 57 tooth. Ive seen replacements go up to 60. Now as it stands now, my truck can easily wheelie off the line, so perhaps off the line speed isn't what Im going for. What I would rather have is low end torque to climb hills or obstacles. I have a feeling that goes against what I initially said about "wheeling off the line..." but if thats what I need, then I'll just learn to live with it or if I can adjust the ESC to be more "gentle" then Ill do that...
    Few people understand the psychology of dealing with a highway traffic cop. A normal speeder will panic and immediately pull over to the side. This is wrong. It arouses contempt in the cop heart. Make the bastard chase you. He will follow.
  2. Geriatric Member VegasJetta's Avatar
    Jan 26th, 2003
    SoPo, Maine
    89 Helios GLI, 01 XJ 4.0, 96 Impreza Syncro, 87 Honda TRX250
    07-31-2012 10:30 AM #2
    That's called the Spur gear. If you want less bottom end and more top end, I believe you have to get a smaller spur gear and adjust your motor upward. You can also get a larger pinion gear at the same time.
    Quote Originally Posted by JacksSenseOfRejection
    Here's a fun fact: if someone is hitting you with a metal pipe, stay down.
