I'd suggest reading the two sticky threads at the top of this forum:
1) "Read This Before Posting! FAQ & Rules for the VAG-COM forum"
2) "VCDS MKVI / MK6 Platform, Handy Coding tweaks"
Your next step will be apparent once you check these out.
#1
i am getting a set of led rear tails for my mk6 gti WITH the rear fog..
i really dont want to wire the rear fog in. .
is the coding the same for the non rear fog led tail lights if i dont wire up the rear fog?
whats the coding i should use for my set of leds so i dont throw a bulb light error code.. thanks guys.
#2
