Page 2 of 2 FirstFirst 1 2
Results 36 to 53 of 53
Thread: n00b Megasquirt User with n00b Megasquirt Question
  1. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    1992 Corrado ABA and MS3-Pro powered, 84 Honda V65 Sabre
    07-30-2012 03:12 PM #36
    Quote Originally Posted by fakename View Post
    Also, I can't seem to import or save just table files. Say I only want to import an ASE table, I can only load full msq files. Do you guys know if that's a TS lite thing?
    Only VE, Spark and AFR tables can be imported and exported.
    The Professor
    Melbourne, FL
    92 Corrado OBD2 ABA Powered by MS3Pro
    M & L EFI Performance
  2. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    '67 rolls royce, '67 mgb gt, and a '13 mom wagon
    07-30-2012 04:04 PM #37
    Quote Originally Posted by Prof315 View Post
    and the boost control related maps as well
    Apr 5th, 2012
    VWoodinville, WA
    91 Golf 16vT
    08-04-2012 11:41 PM #38
    Just saw your posts now. Thanks for clarifying!
    Still working on it, I've got my 60* PW's at 8.4 and climbing because I'm still not getting it to crank until a few tries. Does that seem too high to you guys? All the Cranking tables that I've found online to use for reference are generally much lower, 5-6ish ms PWs at the same temp...
  4. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    08-04-2012 11:57 PM #39
    Do you have full fuel pressure on the initial tries when cranking?
    FS:Sunroof Deflector
    Apr 5th, 2012
    VWoodinville, WA
    91 Golf 16vT
    08-05-2012 12:07 AM #40
    Good question, when I turn the car 'on' my fuel pressure reads 65 (psi right?) or something, high enough to be in the red and I think stays there for each crank until it turns over and hovers around 45. I'll have to double check those numbers tomorrow but I'm pretty sure that's right...
  6. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    08-05-2012 12:10 AM #41
    If you pull a plug or two after the first try or two, are they wet or fouled with fuel?
    Apr 5th, 2012
    VWoodinville, WA
    91 Golf 16vT
    08-05-2012 12:11 AM #42
    hmmm... Haven't looked. I'll have to get a socket to pull those. If they are wet, what specifically does that tell you?
  8. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    08-05-2012 12:13 AM #43
    too much fuel or not enough spark. I'd get a good look at them before backing the fuel down, though.
    Apr 5th, 2012
    VWoodinville, WA
    91 Golf 16vT
    08-05-2012 12:19 AM #44
    Oh, I gotcha.
    'before backing fuel down' Do you say that as a precautionary measure, like I could mess something up if they are in fact wet and I reduce the fuel? Or do you say that as not to worry about backing off on fuel unless I notice that they're getting too wet?
  10. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    08-05-2012 12:21 AM #45
    second, nothing you can hurt when cranking. Well, other than washing the cylinder walls down with too much fuel too often.
  11. Member
    Apr 5th, 2012
    VWoodinville, WA
    91 Golf 16vT
    08-05-2012 12:25 AM #46
    Cool, thanks. I thought so but I can over think things I'll get a puller for those and take a look at them.
    I've yet to do anything with spark plugs (could you tell when I said I don't have a socket for them), so are there other things I should look for? I'll research it in between my researching all the other broken stuff on my mk2 but I know there are things like gap and... I'm sure there are others...
  12. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    08-05-2012 07:24 AM #47
    When comparing settings, dont forget thats raw pulsewidth and does't take into account injector size. Someone with an injector twice as large would have half the pw, etc.
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
  13. Member
    Apr 5th, 2012
    VWoodinville, WA
    91 Golf 16vT
    08-05-2012 01:22 PM #48
    Yeah, that's a good point and I've been trying to find maps with specs close to mine.
    With 42lb injectors, does 8.4 seem excessive at 60*?
  14. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    08-05-2012 06:26 PM #49
    What do they idle at ~4ms?
    -Paul
  15. Member
    Apr 5th, 2012
    VWoodinville, WA
    91 Golf 16vT
    08-05-2012 07:01 PM #50
    They idle around 2.3 PW when warm...
    And no 5th injector either, so I guess my cold PW's would be higher than others because of that, yes?
  16. Member
    Apr 5th, 2012
    VWoodinville, WA
    91 Golf 16vT
    08-29-2012 05:45 PM #51
    Bumping this back up a bit with an update:
    I've continued to increase my cranking PW's and I can now get it to fire on the first crank after 5-10 seconds of cranking. Here is my table (haven't had to crank lower than 50*)
    Seem pretty high to me, what do you guys think? Could that be a problem?
  17. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    08-29-2012 10:46 PM #52
    Little high, how is your fuel pressure during cranking?
    -Paul
  18. Member
    Apr 5th, 2012
    VWoodinville, WA
    91 Golf 16vT
    08-30-2012 02:13 AM #53
    Oh yeah, forgot to mention about that. Well, I've noticed something that seems kind of strange. When I turn my key to the 'on' position, my fuel pressure is around 30-40psi but if I leave the key 'on' for a few seconds before cranking, my FP jumps into the red (don't remember but I think that's like 60+ psi) and the needles jumps around. And it starts much better when I put the key in and immediately start cranking instead of waiting a second or two. Does this sound normal or ring any bells?
