Results 1 to 7 of 7
Thread: Gear Oil and Transmission Fluid Questions
    Jun 17th, 2012
    Slinger, Wisconsin
    2001 Volkswagen Jetta 1.8t Wolfsburg Ediition
    07-20-2012 12:29 AM #1
    So i have an 01 mk4 jetta 1.8t. 5 speed. its got 110k miles. i want to change the transmission fluid. im confused on what to use. like is it neccessary to change gear oil. i see things like theres differnet oil for 1st and reverse. but idk wherer the gear oil would go or if it goes in with the transmission fluid. what type i should use. and same for the transmisson fluid. like what type i should use and how many quarts ill need. im getting my car flashed so i might be running it a little rougher if that matters. thanks for the help
  2. Junior Member pamatt's Avatar
    May 1st, 2012
    2012 GTI
    07-20-2012 01:44 AM #2
    I like Redline. I have used their oils for many years with excellent results. Go to their web site and start reading. If you have any questions email or call them. I change my trans oil every 50,000 miles. If you search you will find the the other info you are looking for.
    May 10th, 2010
    North Jersey
    08 Passat wagon 2.0T 6MT (current). Past: 02 Golf TDI, Dark Beige 88.5 Camry V6 5MT, AE82 Corolla
    07-20-2012 10:55 AM #3
    Quote Originally Posted by TheAnswer#3 View Post
    Yes, it is necessary to change the gear oil every now and then... which changes the oil for all the gears and drives.
    Amsoil MTG worked nicely on my old MK4, with the 02J tranny.... it takes a little over a quart to fill up, so buy 2 quarts.
    2008 Passat wagon, 2.0T 6MT with mods
    Other Rides:
    - 2013 Cannondale CAADX-6
    - 2010 Specialized Secteur Elite
    - 2009 Specialized Rockhopper Comp 29-er
    Jun 17th, 2012
    Slinger, Wisconsin
    07-20-2012 07:43 PM #4
    how much tranny fluid is needed
  5. Member IanJ3VR6's Avatar
    Apr 2nd, 2003
    Burke, Va
    07 GTI, 92 SLC, 06 RAV4
    07-24-2012 07:44 PM #5
    I was always a redline fan in my vw's as well. I also had a brief run of Motul gear 300 which was not the greatest for my applications. I recently changed the trans fluid in both of my vw's with the VW G70 trans fluid and I am impressed with the results. Part number is G 070 726 A2.
  6. Junior Member
    Feb 12th, 2012
    Where the Navy sends me...
    '03 Jetta GLI, '93 Corrado SLC
    08-13-2012 12:42 AM #6
    I've heard that MT-90 works wonders, planning on doing this work very soon
    -Holmes
    People are always surprised that my car smells of crayons
  7. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    08-25-2012 03:19 AM #7
    i use penzoil syncromesh. it has performed well for me. i've got about 100k miles on my gear oil now, i think it's about time for me to change it out
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
