Results 1 to 3 of 3
Thread: 1984 gti rabbit failed california smog
  1. 07-20-2012 12:52 AM #1
    Car Failed Smog
    It failed NO at 15 & 25 mph (see below)
    The car is a 1984 VW rabbit GTI BOSCH CIS mechanical fuel injection, with o2 sensor, NO EGR, the car has about 300k miles. I changed the cat converter in 2004 and the NO went to 0 it has increased over the years and now it is high and failed. I believe my hc and co are fine, what should I do? richen it up by adjusting the air/fuel mixture to get the NO to drop? or install a new cat, results are below
    15mph RPM 1954
    C02 14.59
    O2 0.26
    HC 28; Max 107 Ave 35
    CO .16; Max .63 Ave .19
    NO 1091; Max 845 Ave 564 FAILED
    25mph RPM 2198
    C02 14.90
    O2 0.07
    HC 24; Max 89 Ave 30
    CO 0.10; Max .71 Ave .14
    NO 726 ; Max 726 Ave 464 FAILED
  2. 08-28-2012 07:01 PM #2
    There maybe something you can do to the tune.
    http://webpages.charter.net/meduke/c...adjustment.htm has a how to that fixed a similar issue.
    Could be as simple as taking the injectors off and soaking them in cleaner.
    Jan 7th, 2009
    Glendale, CA
    1987 & 1986.5 Scirocco 16V
    08-29-2012 02:49 AM #3
    Sounds like you need a new catalytic converter.
    Retarding the timing a bit usually lowers the NO
