Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 85
Thread: UroTuning.com | Custom 1.8t Timing Belt Kit $99.99
  1. Banner Advertiser Mike@UroTuning's Avatar
    Jul 18th, 2012
    2004 24v GLi, 2002 TDI 20th Wagon
    07-20-2012 03:06 PM #1
    This basic kit includes the major parts needed to do a timing belt on a Mk4 Golf/Jetta 1.8T.
    Kit Includes:
    - 06B109119A, Timing Belt by Continental
    - 06B109477, T-Belt Tensioner Damper by NTN
    - 06B109243D, Tensioner Roller by NTN
    This product fits:
    1998-2005 Beetle 1.8T
    2000-2006 Audi TT 1.8T
    2000-2005 Golf/Jetta 1.8T
    We recommend you add on a Metal Impeller Water pump, Accessory Belt, Motor Mount bolts and 1 Gallon of G12 coolant which are available as options for this kit.
    Click here to order---> Custom 1.8t Timing Belt Kit $99.99
    Mike@urotuning.com
    UroTuning.com Sales
    OEM & Performance Parts for your VW/Audi
    Owned and operated by hardcore enthusiasts with 15+ years experience
  2. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    07-21-2012 05:44 PM #2
    J u s t i n . W e l t y
    UroTuning.com Owner
  3. Banner Advertiser Mike@UroTuning's Avatar
    Jul 18th, 2012
    07-22-2012 09:51 AM #3
    up
    Mike@urotuning.com
    UroTuning.com Sales
  4. Banner Advertiser Mike@UroTuning's Avatar
    Jul 18th, 2012
    07-23-2012 11:16 AM #4
    bump
    Mike@urotuning.com
    UroTuning.com Sales
  5. Banner Advertiser Mike@UroTuning's Avatar
    Jul 18th, 2012
    07-24-2012 02:16 PM #5
    bump
    Mike@urotuning.com
    UroTuning.com Sales
  6. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    07-24-2012 10:54 PM #6
    UroTuning.com Owner
  7. Banner Advertiser Mike@UroTuning's Avatar
    Jul 18th, 2012
    07-25-2012 10:45 AM #7
    Mike@urotuning.com
    UroTuning.com Sales
  8. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    07-25-2012 07:58 PM #8
    UroTuning.com Owner
  9. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    07-25-2012 07:58 PM #9
    UroTuning.com Owner
  10. Member gli87jetta's Avatar
    Nov 25th, 2001
    Coloradical
    VW, Jetta GLI, 2005
    07-25-2012 09:03 PM #10
    I think those metal impeller Water Pumps might be questionable. The reason I say this is because my timing belt recently got shredded from a failed water pump with metal Impeller. My pistons hit my valves and I needed a new head. It sucked bad since I was at just 48K miles on my Complete Timing belt kit when this happened. According to the shops I talked to the bearings for the metal impellers are too weak and fail. I'm not sure since I can't login to ECS right now to check but I believe I had the Geba Water pump. Either way, they put one with a plastic impeller in this time. YMMV
  11. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    07-26-2012 09:45 AM #11
    Quote Originally Posted by gli87jetta View Post
    We have sold quite a large amount of these kits and never had any issues with any components in the kits. While its possible you had a bad pump. It could have been 1 out of 10,000 that went bad. You can't assume that just because yours went bad that they will ALL go bad.
    UroTuning.com Owner
  12. Banner Advertiser Mike@UroTuning's Avatar
    Jul 18th, 2012
    07-26-2012 12:04 PM #12
    bump
    Mike@urotuning.com
    UroTuning.com Sales
  13. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    07-26-2012 08:12 PM #13
    UroTuning.com Owner
  14. Member gli87jetta's Avatar
    Nov 25th, 2001
    Coloradical
    VW, Jetta GLI, 2005
    07-26-2012 11:48 PM #14
    Quote Originally Posted by JWelty@UroTuning View Post
    Yeah, you're probably right. I just noticed I have oil in my coolant after getting my new head on!!! From what I've researched I appear to have a faulty oil cooler. My coolant looks brown instead of pink. So, I think what happened is the oil in my coolant system caused the metal impeller to fail. Not sure how long that was going on before my pump failed and belt seized? Either way, taking it back to the shop to have this looked at ASAP to hopefully avoid another failure!
  15. Banner Advertiser Mike@UroTuning's Avatar
    Jul 18th, 2012
    07-27-2012 12:18 PM #15
    bump
    Mike@urotuning.com
    UroTuning.com Sales
  16. Banner Advertiser Mike@UroTuning's Avatar
    Jul 18th, 2012
    07-30-2012 12:32 PM #16
    monday bump
    Mike@urotuning.com
    UroTuning.com Sales
  17. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    07-30-2012 09:07 PM #17
    UroTuning.com Owner
  18. Banner Advertiser Mike@UroTuning's Avatar
    Jul 18th, 2012
    07-31-2012 11:59 AM #18
    bump
    Mike@urotuning.com
    UroTuning.com Sales
  19. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    07-31-2012 11:02 PM #19
    UroTuning.com Owner
  20. Banner Advertiser Mike@UroTuning's Avatar
    Jul 18th, 2012
    08-01-2012 12:02 PM #20
    hump day bump!
    Mike@urotuning.com
    UroTuning.com Sales
  21. Banner Advertiser Mike@UroTuning's Avatar
    Jul 18th, 2012
    08-02-2012 12:29 PM #21
    bump
    Mike@urotuning.com
    UroTuning.com Sales
  22. Banner Advertiser Mike@UroTuning's Avatar
    Jul 18th, 2012
    08-03-2012 11:37 AM #22
    bump
    Mike@urotuning.com
    UroTuning.com Sales
  23. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    08-05-2012 06:43 PM #23
    UroTuning.com Owner
  24. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    08-06-2012 09:57 PM #24
    UroTuning.com Owner
  25. Banner Advertiser Mike@UroTuning's Avatar
    Jul 18th, 2012
    08-06-2012 11:19 PM #25
    up
    Mike@urotuning.com
    UroTuning.com Sales
  26. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    08-07-2012 03:03 PM #26
    up we go!
    UroTuning.com Owner
  27. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    08-07-2012 08:44 PM #27
    UroTuning.com Owner
  28. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    08-08-2012 02:56 PM #28
    UroTuning.com Owner
  29. 08-09-2012 03:04 AM #29
    How much for water pump full kit
  30. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    08-09-2012 09:51 AM #30
    Quote Originally Posted by BTimola View Post
    $40 extra to add a water pump to this kit. Check out all the options here: http://www.urotuning.com/Basic-Timin...k4_1.8t_tb.htm
    UroTuning.com Owner
  31. 08-09-2012 09:54 AM #31
    What about the water pump serpentine belt serpentine belt tensioner and seals for cam
  32. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    08-09-2012 10:31 AM #32
    There are options to add water pump, serp belt and cam seals on the page. The serp tensioner can be ordred here: http://www.urotuning.com/Accessory-B...06a903315e.htm
    UroTuning.com Owner
  33. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    08-09-2012 10:09 PM #33
    UroTuning.com Owner
  34. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    08-10-2012 02:57 PM #34
    UroTuning.com Owner
  35. Banner Advertiser JWelty@UroTuning's Avatar
    Jul 18th, 2012
    Tampa, FL
    2013 Jetta GLi K04
    08-13-2012 02:48 PM #35
    Monday Bump!
    UroTuning.com Owner
