Page 1 of 2 1 2 LastLast
Results 1 to 35 of 49
Thread: New AMD build thread
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    07-20-2012 05:09 PM #1
    Just a teaser until I get the pictures sorted.
    Starting point.
    With minimal tweaking.
    "Being in space was great, I had plenty of time to rub one out, which in space is great, but after a while it's like living in a snow globe" -Peter Griffin
    "You could whore yourself out to 1,000 fat chicks for $50 apiece. Or 50 really fat chicks for $1,000. What? Don't look at me like that. Fat chicks need love too. But, they got to pay." -Glenn Quagmire
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    07-22-2012 03:17 PM #2
    These sticks are run @ rated speed @ 1t!!
    FX-8150 in place.
    EK CPU block & EK board block.
    EK heatsink for 990 SB, black piece on the bottom left.
  3. Member PhReE's Avatar
    Sep 16th, 2004
    Taylorsville, UT
    2004 Turbo VR6
    07-22-2012 03:28 PM #3
    Very nice. Is that overclock prime stable? Between the CPU and VRM waterblocks, you should be able to get some pretty good voltage and a nice stable OC. That UD7 should have pretty good VRM's too.
    Typically if you have one stick per channel you can always run 1T, only when you go to two sticks per channel do you have to sometimes drop back to 2T.
    I am definitely an Intel guy myself, but thats a pretty sweet build.
    What are you doing for video and storage?
    -James
    04 GTI Silverstone 24vT :: GT35r - TT 264/260 - Unitronic 630cc - Bosch 044 - Area51 SRI - Full 3" TB :: More in progress
    >> http://zingledot.myminicity.com/ | http://sourceforge.net/projects/imagizer2 <<
  4. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    07-22-2012 07:34 PM #4
    Quote Originally Posted by PhReE View Post
    I haven't run Prime yet. I'm sure it's got some more in it, but I didn't really make much of an effort to OC it yet.
    I have a pair of ASUS DirectCU Top HD5850 & a RevoDrive3-120 GB in a PCI-E slot. I still want to OC the VC's. They have a lot of headroom from stock.
    Other than the CPU, MB, & EK blocks, everything else is being reused, including the water cooling system.
  5. Member theBOYER's Avatar
    Nov 10th, 2008
    Miami, FL
    2012 MINI Cooper S Hatch, 2013 MINI JCW Clubman
    07-22-2012 07:41 PM #5
    Very nice! Are you planning to w/c you GPU's too (secondary loop)?
    ...remember, short controlled bursts
    Steam VendettaGTI
    Origin: VTMTK_Vendetta
    Youtube: InsertCoinToBegin
  6. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    07-23-2012 04:56 AM #6
    Quote Originally Posted by theBOYER View Post
    No plan to do it now, but you never know. It would mean mounting another loop. I could get creative to find the room for it, but would have to start mounting the radiators in stacks. It can become a very expensive hobby.
    The VC's are theoretically capable of maxing out the ASUS SmartDoctor software before actually maxing out their OCing overhead. I'm going to try the MSI Afterburner software also.
    SH*T!! http://www.swiftech.com/mcr320-qp-stack.aspx I could pick up 2 of those on the cheap!! Maybe I should quit while I'm ahead?
  7. Member PhReE's Avatar
    Sep 16th, 2004
    Taylorsville, UT
    2004 Turbo VR6
    07-23-2012 12:56 PM #7
    Wow, that is a good price on the rads, heh. Quit now? Haha it never stops!
    -James
  8. Member morbs_gt's Avatar
    Mar 21st, 2008
    Paris, FR
    07-23-2012 01:20 PM #8
    Watching
    Sent from my vwvortex account.
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    07-23-2012 04:31 PM #9
    I think they are closing out the leftovers. They were the result of a forum asking for that type of set-up, Swiftech stepped up & produced them, & now it's no longer being produced. They are a unique product. You just plug them into each other until you have what you want, add fans, & then the barbs go on the outside radiator.
    It gets complicated with the fans & shrouds. A double stack could have 3 rows of fans pushing & pulling air through the stack. The 2 pictures above have the basic single fan row set up, but more can be added to the outsides.
  10. Member theBOYER's Avatar
    Nov 10th, 2008
    Miami, FL
    07-23-2012 04:35 PM #10
    almost seems more worth it to have one of those external cooler things you showed me
    Steam VendettaGTI
  11. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    07-23-2012 06:27 PM #11
    Was it the water chiller?
  12. Member theBOYER's Avatar
    Nov 10th, 2008
    Miami, FL
    07-23-2012 07:45 PM #12
    Quote Originally Posted by CaptainQualude View Post
    yeah
    Steam VendettaGTI
  13. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    07-24-2012 03:41 AM #13
    This is the only English review of the chiller I am aware of.
    http://www.bit-tech.net/hardware/coo...iller-review/1
    Performance PC's in Florida sells it, so there are probably other US retailers too.
  14. Member Power5's Avatar
    Jun 19th, 2001
    Cincy, Ohio
    '99 XJ 6"-Aussied d44-35" TSL-XRC8 / '11 Sonata white yay
    07-24-2012 08:36 AM #14
    Not quite sure how that rad stack works. I have to assume there is something in the end caps to direct the water or it would just flow straight through the barbs on the first rad and only use the second rad. Would make sense if the inlet was on the top rad and the outlet was on the bottom rad, but I just don't get how it works as pictured.
    Aaron
    PSN: RealPower5
  15. Member PhReE's Avatar
    Sep 16th, 2004
    Taylorsville, UT
    2004 Turbo VR6
    07-24-2012 12:05 PM #15
    Quote Originally Posted by Power5 View Post
    If you have enough flow the back pressure in the second rad will cause flow thru the first rad. This technique also slows the water down giving it more time to cool in the rad.
    -James
  16. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    07-24-2012 09:02 PM #16
    Makes sense, but might be tougher to bleed the system.
  17. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    88 F150, 04 RX8
    07-24-2012 10:18 PM #17
    Hmm... so what do you need this much eight core power for?
    You running Mars trip simulations for SpaceX?
    No.. seriously.
    Is this just like a dyno queen car that is never raced... do you have a need for such power?
    Or is this about bragging rights?
    And I am not "hating" on your build of OC.
    Just trying to figure out this OC thing.
  18. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    07-24-2012 11:18 PM #18
    No.. seriously.
    I have 2 systems, one primary, & one secondary which is the hand me down everyone else in the house uses. The secondary system was an Intel quad-core that the MB died on. It's old enough at this point that the CPU & MB are obsolete, & the MB is no longer available anywhere. For $500 in parts I did an upgrade for myself, & passed the 2 YO system I was using on to the secondary system. It comes down to $500 for current technology, or a store bought $500 system that was obsolete 3 years ago. The speed difference is very noticeable in just doing everyday tasks. Anybody who tells you otherwise is full of sh*t.
  19. Member PhReE's Avatar
    Sep 16th, 2004
    Taylorsville, UT
    2004 Turbo VR6
    07-24-2012 11:24 PM #19
    No.. seriously.
    Some peoeple, like the OP, and I, can actually tell the difference between a normal persons 2-3Ghz computer and a highly overclocked 4-5Ghz computer, just moving thru windows and surfing the web even. Frankly most stock cpu's piss me off because they are too slow. THere are so many places a web browser can lag and does lag on a 3Ghz cpu you would be surprised.
    It's just like driving a 450+Whp FWD car. I love my VRT too
    -James
  20. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    07-25-2012 12:10 AM #20
    When I'm at a friends house, it's always, WTF is wrong with your system? When they use one of mine they are left speechless & sometimes drooling. ;-) OTS systems have a purpose, like when you are trying to kill time at work.
  21. Member PhReE's Avatar
    Sep 16th, 2004
    Taylorsville, UT
    2004 Turbo VR6
    07-25-2012 12:31 PM #21
    Haha no kidding. I really hate using my work laptop after using my 4.8Ghz 3930K, but hopefully that laptop will be replaced soon. Although I usually end up upgrading my machines at work in some way eventually anyways heh.
    -James
  22. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    07-25-2012 03:49 PM #22
    I wanted to buy a bare-bones laptop years ago & nobody had one, bought an OTS laptop, & then you know what happened within a year, OCZ came out with one. When the OTS laptop died I went looking for the OCZ, & they had been discontinued.
    This is what it looked like when I first opened the box, and in original passive air cooled form.
    The MX-4 TIM & the bundled leads to clean up the secondary system case with 90° HD connectors.
  23. Member PhReE's Avatar
    Sep 16th, 2004
    Taylorsville, UT
    2004 Turbo VR6
    07-25-2012 04:10 PM #23
    Clevo/Sager still make/sell barebones laptops. You can get them here http://rjtech.com/shop
    -James
  24. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    07-25-2012 04:49 PM #24
    I'm pretty sure MSI does now also, but not in the market for one anymore.
  25. Member PhReE's Avatar
    Sep 16th, 2004
    Taylorsville, UT
    2004 Turbo VR6
    07-25-2012 04:51 PM #25
    Yeah, that company sells the MSI barebones chassis too. Pretty cool lil site
    -James
  26. Member Power5's Avatar
    Jun 19th, 2001
    Cincy, Ohio
    07-25-2012 05:21 PM #26
    Is that a better setup than doing as I said? Cap the one in between barb and just use the other to transfer from one rad to the other. Only real problem is tubing routing would be a bit harder since barbs are on opposite sides of the huge rad stack.
    OC computers are definitely a noticeable difference for me. Also, why not OC to get better than intel 6 core performance out of my $199 2600k?
    Aaron
    PSN: RealPower5
  27. Member PhReE's Avatar
    Sep 16th, 2004
    Taylorsville, UT
    2004 Turbo VR6
    07-25-2012 08:01 PM #27
    Well essentially all you need to do is hook them up like they are in the pic and have a big pump and then 2-3 sets of fans and it would work great.
    -James
  28. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    07-26-2012 12:23 AM #28
    There are so many fittings available that something could be rigged up to work, even if it meant crossing the flow over to the second radiator with 90° fittings, & then crossing it back over when it exits.
    Lots of fans adds expense & noise, but you do what you have to to make it work.
  29. Member PhReE's Avatar
    Sep 16th, 2004
    Taylorsville, UT
    2004 Turbo VR6
    07-26-2012 01:13 AM #29
    Yeah, but I am a lot less sensitive to fan noise as most people. I have some mild PWM delta 120's on my H80 for my 3930k, they are pretty quiet when its idling, but certainly kick up some noise if it is cranking on something.
    -James
  30. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    07-26-2012 01:58 AM #30
    Fans have come a long way since the Delta 60mm 10,000+ RPM jet engines of the past, but I still can't deal with too much noise. I settled on 120 mm 70 CFM 38mm thick fans as to what I was willing to deal with on a daily basis, & also increased the radiator surface area.
  31. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    88 F150, 04 RX8
    07-26-2012 02:06 AM #31
    Some peoeple, like the OP, and I, can actually tell the difference between a normal persons 2-3Ghz computer and a highly overclocked 4-5Ghz computer..
    Yeah... nobody else could tell the difference.
    Seriously- I was not trolling or trying to be an ass (not that I have to try).
    But supercharging a new 5.0 Mustang just so it is faster merging in traffic?
    IDK... seems like a dyno queen to me.
    On that note- let me preface by saying I have never tried any serious OCing (that was stable enough to think it was useful).
    But then again- I don't have central air/heat, so pc cooling is an issue depending on the weather.
  32. Member PhReE's Avatar
    Sep 16th, 2004
    Taylorsville, UT
    2004 Turbo VR6
    07-26-2012 12:02 PM #32
    Haha yeah, back on a socket A Athlon I had one of those with an Alpha heatsink, remember those guys..? Heh
    Well, it's almost more noticeable when you come from a fast computer to a slow one, you are like man I'm slogging through molasses, where as you might just be used to the 'slow' computer you have now and not even realize it Unlike cars on the street, a computer can never be TOO powerful
    -James
  33. Member
    Feb 11th, 2009
    Lewiston, Maine
    2001 Wolfsburg Jetta
    07-26-2012 12:33 PM #33
    I still have a 2500+ Barton core with a Volcano 6+. It howls! Horrible noise. I can't stand listening to noise after using HSF with 90 and 120mm fans. I retired it, finally
    QFT
    Tax? I don't mind paying state sales tax. Every time a see a pothole, a school that is falling down or a canceled essential state program, I remind myself why.
    535 members of congress plus 1 pres screwing us all the time...that's dirty pirate hooker level gang rape.
  34. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    07-26-2012 06:52 PM #34
    I may have had one of those Alpha's, but can't remember for sure. I did have one of the Volcano's though.
    It would be like the difference between riding a bicycle & driving a car from point A to point B. If you never were aware a car existed you would be content with the bicycle.
    It's used a few hours a day year round. Definitely not a dyno queen, & anyone could tell the difference, it's that noticeable.
    OC on water & the best it will be is ambient temperature. Oc on air & it will always be above ambient temperature. There is a definite difference in room temperature between the two methods, plus air cooling is too loud for my tastes at this point in time.
  35. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    07-26-2012 06:54 PM #35
    Back on topic.
    This is the one hanging off the back of the case.
