Moogie on ebay has those from time to time.
Anyone have or know where to get these Bushing for 90 Cabriolet?
Thanks!
Where are my grounds ?
What part are you referring to?
If you have loose lower steering column bearings, look at my sig...
You could also use a simply hose clamp from the hardware store. That's how I fixed mine last year and have had no problems since. The cage was still intact; my rubber seal had cracked and broken off allowing the bearing cage to slide down the column and cause an up/down wobble. Quick, easy, cheap fix.
1991 Cabriolet - 1.8L 4 cyl-8V 5spd - Tornado Red w/Black Top - 14" Avus "Snowflake" Dolomite Grey stock rims.
