VWVortex.com - Rare Eurovan Gearbox
    Results 1 to 13 of 13
    Thread: Rare Eurovan Gearbox
      Jun 8th, 2011
      NJ
      2002 Eurovan, 2013 Mini Cooper, 2006 Sprinter, 1961 Thunderbird
      07-21-2012 04:11 AM #1
      No longer available !!
      I am selling a used VW Eurovan 5speed manual transmission code 02G AFK
      fits on to a 2.5 TDI engine (not an VR6 ) Very Rare , is from a European model year 2000
      I have attempted to mate it with a V6 24v but not even close
      The only flaw is one of the mount holes was cracked during front end damage to the van , and it was welded n looks good
      Jun 8th, 2011
      NJ
      07-21-2012 09:37 AM #2
      Jun 8th, 2011
      NJ
      07-25-2012 02:29 AM #3
      Bump
    4. Member Rob C's Avatar
      Jun 19th, 2001
      Oregon
      1958 Bug, 1985 Scirocco, 1997 Passat Wagon TDI, 1999 Eurovan Weekender TDI
      07-26-2012 08:57 PM #4
      I can't find a listing for code AFK trans online. Do you know what Ring/Pinion and gear ratios are? Thanks!
      Rob
      Jun 8th, 2011
      NJ
      07-27-2012 10:43 AM #5
      Will look in a bit
    6. Member
      Jun 8th, 2011
      NJ
      07-28-2012 11:46 AM #6
      AFK gearbox
      1st 3,909
      2nd 2,118
      3rd 1,346
      4th 0,972
      5th 0,729
      Axle drive. 3,905
    7. 08-02-2012 05:17 PM #7
      Quote Originally Posted by Zoliaxk View Post
      AFK gearbox
      1st 3,909
      2nd 2,118
      3rd 1,346
      4th 0,972
      5th 0,729
      Axle drive. 3,905
      Was used from 09/95 -> 07/99
      But it is an 02G transmission and not an 02B so it wouldn't fit any of the 4 cylinder blocks...
      http://www.t4-wiki.de/wiki/Getriebe
      Info where it was used:
      http://www.t4-wiki.de/wiki/Getriebekennbuchstabe
      Will only mate to I5 engines...
      Jun 8th, 2011
      NJ
      10-07-2012 03:16 AM #8
      Bump
      Jun 8th, 2011
      NJ
      10-28-2012 12:56 AM #9
    10. Member
      Jun 8th, 2011
      NJ
      11-15-2012 02:47 AM #10
      Bmp
    11. 11-18-2012 12:54 PM #11
      Will it fit into my Westy... would really like to move to a 5-speed. I have been reading on the Samba about Subaru convert.. but it sounds like a kit bitch"
      Jun 8th, 2011
      NJ
      02-04-2013 12:07 AM #12
    13. Member
      May 1st, 2014
      Canada
      02 EVW VR6, 05 Jetta Wagon 1.8t. 02 Jetta 2.0,
      09-21-2014 06:57 PM #13
      Hi Zoliaxk,
      I saw your posting and wanted to know what became of this transmission. Is it still in NA? Can you put me in touch with whoever you sold it to?
      I have an 02G AFL and would like to compare the transmissions -- I want to see the difference in bell housings and confirm whether the back half or the gear house is indeed the same. I would like to share whats learned from the two so as that others can do 5-speed conversion.
      Thanks
