VWVortex.com - big vacum leak makes my car runs better? w t f....
    Results 1 to 2 of 2
    Thread: big vacum leak makes my car runs better? w t f....
    1. Member tractorsosa's Avatar
      Aug 18th, 2009
      05 gti 1.8t(sold), 03 gti vr6 24valves, 03 nissan xterra(totaled),03 bmp 20th(daily), dbp .:R vrt ,
      07-22-2012 08:27 AM #1
      k, here is the deal, i did replace my standalone for a c2 ecu in order to reduce the power of the car, and slowly make it look more stock,
      first of all when i plug the new ecu with the c2 software, the car starts just right up, let it run for a lil bit, and i found a big vacum leak, then sealed with my hand and the car stalls and shuts off,
      now the car is hard to start and doesnt idle good, unless i give it some gas, otherwise it will shut off again! what i am missing here?
      leak was found in the big plastic hose from the mnfold to the block off plate in the valve cover,
      i have the correct injectors for the tune as tuner recomends,
    2. Member tractorsosa's Avatar
      Aug 18th, 2009
      07-25-2012 07:45 PM #2
      nobody?
