Results 1 to 9 of 9
Thread: 9.552 @ 150.9 i got both my '50s and almost didnt stop!
  1. 07-22-2012 11:55 AM #1
    and almost didnt stop. unbeknownst to me, on this last pass of the day (for obvious reasons LOL) the staging brake decided to puke all over. but i didnt know it until the pass was made and it was time to stop. and i got all of this fountain show on vid as i use a gopro to specifically watch the shifting action. the brakes felt a little bit mushy after the burnout, and the staging brake didnt feel as tight either.
    the day was great, made 3 full passes in a row, all shifted great, each one progressively quicker than the previous by .13 sec each. picked up 37 mph on the back half of the first pass even.
    i am working on processing all the videos, and Jon is going to do some intro work i think. so stay tuned for those.
    but boy MF HOWDY, what a world of difference it makes actually being able to shift easily and cleanly!!!!
    my tuner told me once i run a 9.5x he will give me >800 at the wheel.... well i did it!
    here is the air info for each run:
    Quote Originally Posted by 9.81 run
    07-21-2012 10:02:38 Wind from N at 3 mph
    Elev : 183 ft....................................Temperature 67.00°
    Barometric Pressure 30.20...............Humidity 73.00%
    Standard Rel Air Density 98.80%......Track Rel Air Density 99.40%
    Effective Altitude 442.00 ft................Tail Wind 3.00 mph
    Quote Originally Posted by 9.68 run
    07-21-2012 12:06:43 Wind from N at 0 mph
    Elev : 183 ft....................................Temperature 71.00°
    Barometric Pressure 30.18...............Humidity 55.00%
    Standard Rel Air Density 97.90%.....Track Rel Air Density 98.60%
    Effective Altitude 731.00 ft................Tail Wind 0.00 mph
    Quote Originally Posted by 9.55 run
    07-21-2012 13:49:12 Wind from N at 0 mph
    Elev : 183 ft....................................Temperature 73.00°
    Barometric Pressure 30.16................Humidity 51.00%
    Standard Rel Air Density 97.50%......Track Rel Air Density 98.10%
    Effective Altitude 880.00 ft................Tail Wind 0.00 mph
  2. 07-22-2012 03:49 PM #2
    Geesh! Almost had to Flintstone it
  3. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    1984 GLi 20v, '06 M3, '10 Ninja, '10 690 Duke
    07-22-2012 06:29 PM #3
    **** was leaking before you even got to the line, then..pissing in all directions!! sketchy!! glad you had the chute dude, big time.
    :HOMEGROWN MOTORSPORTS:1:4.9 VulcanWorks SuaSponte #13Dead Rabbits 1.8l20vAEB3651GonzoFerrera1000cc1552.billet3071rSE M80mmAWIC.H&R.PagParts.Snow034clutchmasters.IE.198 4JettaGLi
    Quote Originally Posted by frechem View Post
    I like my women how I like my whiskey; aged 18 years and mixed up with coke.
  4. Member A2TDI's Avatar
    Apr 8th, 2004
    MK2 wannabe Drag car
    07-22-2012 07:23 PM #4
    congrats on the run...did you have to change your underwear after? lol
    90 4 dr jetta 2L 20V hx super 40 at 30 psi 11.28 @ 129.1 mph 2360lbs
  5. Member agnhare77's Avatar
    Apr 13th, 2005
    front royal va
    78 rabbit
    07-22-2012 08:28 PM #5
    fast, faster, BOOGIE
  6. Member schwartzmagic's Avatar
    Apr 29th, 2007
    MIA
    2011 Jetta TDI; 05 VW Jetta GLI 5857BT
    07-22-2012 11:20 PM #6
    Congrats bud!!!
    Aaron, was curious as to how much of a a difference would being higher than sea level make? I know 183 ft isn't too high up but it has to make some kind of difference.
    Can't wait to see what the car does > 800whp... Gonna be hurtin some egos lolz.
    Local honda dude on same turbo as yours is making 900+whp on that thing...
    Dec 14th, 2001
    Greensburg, PA
    07-23-2012 09:47 AM #7
    Awesome Aaron! Keep-up the good work and keep listening to Kevin.
    Life begins at 101 kpa ...and so does poverty--Lugnuts Calhoun
  8. Member PartsBlowOut's Avatar
    May 10th, 2009
    Stock Blocks, NJ
    B5 s4
    07-23-2012 06:51 PM #8
    congrats dude!! now go fix your brakes
    Lugtronic, Vicente Motorsports, and
    Wong_Tuning "If it ain't Wong its not right"
  9. 07-23-2012 08:34 PM #9
    done deal. already bought a new staging brake, a CNC one this time. talked to Jamar about this one and they want to see it to fix it.
    and i will be running Sunday at the Bug-In, trying some more. i am just going to reconnect the brake lines under the car to bypass the staging brake.
