Results 1 to 33 of 33
Thread: Any K04 4MO Tiguans Out There?
  1. Member SkullV's Avatar
    Jun 15th, 2010
    2010 Tiguan SE 4Motion
    07-22-2012 05:35 PM #1
    Just bought an APR K04 kit for my 2010 4MO. Just wondering if anyone else has this setup? I'm going to be running it with stock intake (diffuser grille removed and K&N panel filter) and stock downpipe. Just want to keep things 100% OEM looking/sounding. With the detuned K04 file I'm hoping to be making around 320/340 at the wheels.
    Mar 25th, 2010
    apple valley MN
    2012 tiguan SE 4motion(had a 2007 GLI)
    07-22-2012 05:41 PM #2
    i hope to someday....
  3. Member DT EXP's Avatar
    Jun 15th, 2007
    San Antonio, TX
    09 TiG 6MT and a 1990 Cabriolet
    07-22-2012 10:26 PM #3
    Not many K04 tiguans running around.. but you can check out my build, but I went full on with FMIC, Down pipe, ect...
    Good luck tho, and get some numbers after your install..
    My Build
    http://forums.vwvortex.com/showthrea...s-Build-Thread
    Quote Originally Posted by ih8erickempf View Post
    Im a dude and drive an EA edition cab w/ teddy bear wheels... sometimes you just gotta have some fun at the expense of the stereotype
  4. Junior Member
    Jul 21st, 2012
    2012 Tigan SE with Pano and Nav
    07-22-2012 10:52 PM #4
    I've got the wife approval for a KO4 on the 2012 4mo, running just an APR stage 1 91 octane right now.
    I'm hesitating on pulling the trigger because here in utah we generally can't get 93 octane and lack of 4mo downpipe means that the two largest improvements to be had with the K04 aren't possible for me. Intercooler probably isn't in the cards for me as I'm not racing it. Carbonio intake, downpipe, 93 octane seems like the minimum I'd want to do along with the K04 but am out of luck on 2/3 of those.
    Are you really leaving everything stock and just putting the bigger blower on?
    Mar 25th, 2010
    apple valley MN
    07-22-2012 11:34 PM #5
    not sure how much but it says they make one for the 4motion....
    http://www.goodspeedperformance.com/...from-goodspeed
  6. Member SkullV's Avatar
    Jun 15th, 2010
    07-22-2012 11:34 PM #6
    Quote Originally Posted by dnellans View Post
    Yes, I'm told by a few people who have run GTI's and A3s with stock DP that there isn't a whole lot of gain with the downpipe. An intake is a tiny gain for sure, but may help a bit.
  7. Junior Member
    Jul 21st, 2012
    07-23-2012 09:25 AM #7
    Thats a good datapoint to have, thanks! Based on APR's dyno charts it looks like intake/downpipe do more for allowing the HP to not fall at high RPM than to increase the peak. Important if you're a racing, less important if its just a spirited DD.
  8. Junior Member IR3Impulse's Avatar
    May 14th, 2008
    Nassau, New york
    2011 VW Tiguan SE 4Motion
    07-23-2012 05:17 PM #8
    I will be installing it in two weeks. I removed my APR Carbonio Intake system. I also want a clean/stock sleeper Tiguan No luck on the downpipe for a 4Motion Tig. I can't believe no one is fabricating a downpipe for the 4Motion Tiguan. Goodspeedperfomance.com did but they will cause an annoying CEL due to different state emission.
    Mar 25th, 2010
    apple valley MN
    07-23-2012 07:51 PM #9
    i had the same cel on my gli but they took that out when i got my apr tune... should just be the 2nd o2 sensor...
  10. Member
    Mar 25th, 2010
    apple valley MN
    07-23-2012 07:52 PM #10
    oh, you selling that carbonio?
  11. Member SkullV's Avatar
    Jun 15th, 2010
    07-23-2012 08:51 PM #11
    Quote Originally Posted by IR3Impulse View Post
    Gentlemen, Techtonics Tuning DOES make a 4MO downpipe (and it's cheap). Arin@APR also indicated to me that the Golf R Downpipe would likely fit with minor modifications to the subframe bracket. ANY of the downpipes will cause a CEL without a test pipe file (APR or otherwise) in the tune. The solution is installing an o2 sensor spacer in-line with the 2nd o2 sensor.
    Techtonics Tuning Downpipe:
    http://techtonicstuning.com/main/ind...oducts_id=1770
    42DD spacer:
    http://store.42draftdesigns.com/O2-S...cer_p_306.html
    RAI Spacer:
    http://www.raimotorsport.com/RAI-J-P...p/11621vib.htm
    If you have any other questions about how to make it work for whatever state you are in don't hesitate to ask.
    Mine will be installed on Monday so I'll let you all know how it feels.
  12. Junior Member
    Jul 21st, 2012
    07-23-2012 11:57 PM #12
    Awesome info. Are you running an APR tune now or stock? Any chance of a dyno run before and after?
  13. Member SkullV's Avatar
    Jun 15th, 2010
    07-24-2012 10:56 AM #13
    APR Stage 1 right now. No dyno though. I will dyno with the k04 on stock DP just because no one at APR can give a concrete answer on power without a DP.
  14. 07-27-2012 09:15 PM #14
    subscribed
    Sent from my LG-P999 using Tapatalk 2
  15. Member SkullV's Avatar
    Jun 15th, 2010
    07-30-2012 09:55 AM #15
    It's at the shop having the K04 put on as I type this! It seems that there is going to be a hold up though due to a P0507 code. I'm hoping it's something that can be fixed without ordering parts, but based on some quick research it seems that intake flapper, throttle body, and diverter valve are the most likely culprits. That means ordering parts and not getting the car back until tomorrow afternoon at the earliest.
    On the plus side, my loaner is a brand new 2012 Tiguan SE and I like the interior of my 2010 MUCH better, besides the steering wheel of course.
    2009 GTI - APR Stage 1 - Sold
    2011 GTI - APR Stage 2 - Sold
    2010 Tiguan 4MO - APR K04 - Sold
  16. Member MacProD300's Avatar
    May 19th, 2010
    ME
    2010 VW Tiguan Wolfsburg Edition APR Stage I
    07-30-2012 03:23 PM #16
    Please Post Pics and Video of your newly installed K04 this might just give me the extra push to get one.
  17. Member SkullV's Avatar
    Jun 15th, 2010
    07-30-2012 03:54 PM #17
    Quote Originally Posted by MacProD300 View Post
    Not going to be a whole lot to see under the hood, but I'll post some straight line acceleration video for you
  18. Member SkullV's Avatar
    Jun 15th, 2010
    07-30-2012 05:32 PM #18
    Fun little list:
  19. Member ZLEB's Avatar
    Dec 9th, 2010
    LI-NY
    2012 Tiguan S
    07-31-2012 06:21 AM #19
    Quote Originally Posted by SkullV View Post
    Fun little list:
    I think real life results would be in that order, those srt8 jeeps are monsters
  20. Member SkullV's Avatar
    Jun 15th, 2010
    07-31-2012 10:19 AM #20
    Quote Originally Posted by ZLEB View Post
    Yeah. I should have also mentioned that the chart is labeled wrong. It should be Weight/HP and Weight/TQ. Oh well. Should be fun, I SHOULD have the car back today. Dealership is waiting on a PCV valve that was faulty.
  21. Member SkullV's Avatar
    Jun 15th, 2010
    07-31-2012 01:34 PM #21
  22. Member ZLEB's Avatar
    Dec 9th, 2010
    LI-NY
    2012 Tiguan S
    07-31-2012 02:20 PM #22
    Where's the manifold? Or am i just not seeing correctly
    Should have just bought a ko4 at wf , i had to leave early the temptation was so great
  23. Member SkullV's Avatar
    Jun 15th, 2010
    07-31-2012 02:42 PM #23
    Manifold is to the back left of the turbo picture. The turbine housing is cast into the manifold on our IHI turbo and the Borg Warner K04 that is going in.
  24. Member ZLEB's Avatar
    Dec 9th, 2010
    LI-NY
    2012 Tiguan S
    08-04-2012 07:17 PM #24
    So is there a 4 motion ko4 tig out there yet?
  25. Member SkullV's Avatar
    Jun 15th, 2010
    08-04-2012 10:33 PM #25
    Yes there is! There were some complications with the install, I dont yet have all the features in my software flash (93 oct works fine though), and the dealership mis diagnosed the check engine light slits still there (Bill Jacobs VW in Naperville, IL sucks!!!) but DAMN does this car move!!
    I'm on vacation in Baltimore right now visiting family, but when I get home I'm putting an SPM intercooler on and I'll post some acceleration videos.
  26. 08-08-2012 04:28 PM #26
    Who did your install on the KO4?
  27. Member SkullV's Avatar
    Jun 15th, 2010
    08-09-2012 11:28 AM #27
    Quote Originally Posted by Lawfarm View Post
    The install was done at a local VW dealer. They did a TERRIBLE job. Until that situation is resolved I'm going to refrain from posting more info.
    Here's a little video for those who asked:
  28. Member ZLEB's Avatar
    Dec 9th, 2010
    LI-NY
    2012 Tiguan S
    08-09-2012 11:54 AM #28
    Awesome.
    My issue hasn't been resolved yet either the rcm has yet to even contact me
  29. Member D-Caf's Avatar
    Mar 21st, 2009
    East Coast
    2009/VW/Tiguan
    08-09-2012 08:59 PM #29
    Though I appreciate you posting a video of it, and dream of doing the K04 myself, I do wish you hadn't done 0-85mph in what looks like a residential neighborhood. One kid runs out in the street late at night trying to catch the cat that got out the door, and someone dies.
    If you are going to do something like this, could at least do it on the freeway when there isn't much traffic.
    2009 Black/Brown Tiguan SE w/4Motion
    - Added: Revo Stage 1 w/Select Plus, RNS-510, Volk-L Bluetooth, 2" Class 3 Hitch + Trailer Module, VAG-COM Micro-CAN, 19" Savannah 2Tone
    2001 Black/Tan Golf GLS 1.8T w/Monsoon (Wifes)
    - Added: 6 Disc Changer, K&N Filter
  30. 08-10-2012 04:46 AM #30
    Impressed with the acceleration, but I've got to agree with the other guy. Go to an on ramp, or pull over on the freeway.
  31. 08-10-2012 08:09 AM #31
    Quote Originally Posted by D-Caf View Post
    Not only that, the cat could die too!!!
  32. Member SkullV's Avatar
    Jun 15th, 2010
    08-10-2012 10:34 AM #32
    Quote Originally Posted by raffor View Post
    All good points. We made sure it was "safe". Buddy drove the street seconds before to make sure no one was outside.
  33. 08-10-2012 09:58 PM #33
    I'm in Aurora. Any chance I could get a few details from you on cost and the issues you've had with the install? Bill Jacobs?
