Results 1 to 2 of 2
Thread: Where can I find some help for a Carter YF carburetor?
  1. 07-22-2012 11:59 PM #1
    Hi,
    As the title says, I'm looking for some help for a Carter YF carb for a 1951 International Harvester with the 220 CI engine. Are there any message boards I should check out?
    Here are the details in case anyone out here ca help out.
    The engine seems to idle well enough (I don't have a tachometer so I don't know what the idle speed is).
    The engine stalls/nearly stalls when I hit the throttle quickly. The accelerator pump seems to be working properly (I can see a stream of fuel spray from the accelerator nozzle).
    What else could cause this problem? Is there an idle speed adjustment on this carb/engine setup?
    thanks
    Jun 14th, 2001
    Music City USA
    79 Scirocco 82 Rabbit Truck 85 Golf D 87 GTI 97 Passat TDI 03 TT
    07-24-2012 11:21 PM #2
    find a local garage and get some old dude to look it over. Maybe the carb is gettin old and needs a rebuild.
