Results 1 to 22 of 22
Thread: 2.0t Aba
  1. 07-23-2012 02:18 AM #1
    white gunk in motor. Its my 1st mk3 Jetta, no Bentley manual, need some thought on parts I need. Lmk. Thanks guys
    Sent from my SGH-T959 using Tapatalk 2
  2. 07-23-2012 02:25 AM #2
    Pics of my mk3. Got em for $300 =]
    BTW. Sorry about the up side down pic.
  3. 07-23-2012 03:51 AM #3
    Help plz
  4. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    1984 GLi 20v, '06 M3, '10 Ninja, '10 690 Duke
    07-23-2012 03:07 PM #4
    white gunk on your oil cap?
    that is normal..it's from condensation in your engine, perfectly normal.
    if can post pics of said white gunk
    :HOMEGROWN MOTORSPORTS:1:4.9 VulcanWorks SuaSponte #13Dead Rabbits 1.8l20vAEB3651GonzoFerrera1000cc1552.billet3071rSE M80mmAWIC.H&R.PagParts.Snow034clutchmasters.IE.198 4JettaGLi
    Quote Originally Posted by frechem View Post
    I like my women how I like my whiskey; aged 18 years and mixed up with coke.
  5. Member 808Bora's Avatar
    Feb 9th, 2003
    808 Hawaii
    06 Passat
    07-23-2012 05:21 PM #5
    U bought dis off CL? According to da owner, didnt it have a blown headgasket or something wrong w/da engine?
    Team.Foreign.Objects Est.2003
    Its not a Fad, Its a LIFESTLYE!
    Broken Promises
  6. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    07-23-2012 05:29 PM #6
    that would also explain a lot lol
  7. 07-23-2012 10:51 PM #7
    Yeah, I just confirmed with a compression test. I've been reading some forms and at first I thought it was the oil cooler cause the upper radiator hoes was half way crusty. Now I need to do a head gasket job but i don't know the tools I need parts I need to buy. I need help
  8. 07-23-2012 10:52 PM #8
    I really need a parts list.
  9. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    07-23-2012 11:28 PM #9
    valve covert gasket
    head gasket
    hopefully you have arp head bolts, which can be reused
    coolant flange o ring
    oil, oilfilter
    coolant
    pretty much it for parts
    Sent from my SPH-D710 using Tapatalk 2
  10. 07-24-2012 01:54 AM #10
    Any special tools needed?
  11. 07-24-2012 04:01 AM #11
    Quote Originally Posted by jkruzin View Post
    Is it an automatic trans? If so, I would add "road flares" to your list of tools needed.
    OSD #26 - "Because he's thirsty... Dummy."
  12. 07-24-2012 05:45 AM #12
    Of corse its not an automatic. Who put Turbo on an automatic. Ill put a super charger on a automatic. That's my next project =] my gf wants to go on a euro Cruz too.
  13. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    07-24-2012 03:52 PM #13
    the timing belt tensioner wrench and the long bits to pull the headbolts out and put the new ones in. the #1 tool you need is a bentley manual...that way you have it all right there, step by step, torque specs, patterns, etc etc.
    it's actually pretty simple to pull that head..the added turbo stuff on there is jsut nuts and bolts..if you've never done it i auggest you have someone who has help you.
    i recommend replacing hte waterpump and timing belt and such while your in there...wouldn't hurt!!! who knows if it has ever been done.
  14. 07-24-2012 04:30 PM #14
    How much do you have into this car? It may be worth buying a running, driving one and bolting on the stuff you want to keep.
  15. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    07-24-2012 04:33 PM #15
    valid point
  16. 07-24-2012 07:59 PM #16
    Just $300 but don't have that much time to work on em. I'm trying to get all the tools and parts I need so I can fix everything 1 day. =]
  17. 07-24-2012 08:57 PM #17
    One day is unlikely. You'll need to get that head to a machine shop and get it re-surfaced if you do go this route.
  18. Member
    Aug 4th, 2000
    Kailua, HI
    MK1 GTI, '95 Golf 2.0T
    07-26-2012 05:01 PM #18
    torque wrench is a must...good luck with the project. Has there been any bottom work done? If not since you are replacing head gasket buy this http://www.kineticmotorsport.com/pro...R-494-142.html or double stack aba gaskets to lower comp.
  19. 07-27-2012 03:51 PM #19
    Avw4me: thanks for the info =]
  20. 07-28-2012 01:57 AM #20
    Do I need to replace the bolts and nuts after I take the head off?
  21. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    07-28-2012 04:26 AM #21
    the head bolts yes, any others no
  22. 07-28-2012 08:03 AM #22
    Vegeta gti; thanks for the info.=]
